Comparing matrices between 2 different codes and viewing of matrix
Tue May 27 07:52:01 CDT 2008
    You use EITHER PetscViewerCreate() and PetscViewerSetType() and
PetscViewerFileSetName() OR PetscViewerASCIIOpen()
so use
> call PetscViewerASCIIOpen(MPI_COMM_WORLD, "matrix.txt",viewer,ierr)
>> call MatView(A_mat_uv,viewer,ierr)
> call PetscViewerDestroy(viewer,ierr)
On May 27, 2008, at 5:57 AM, Ben Tay wrote:
> Hi Barry,
> Thanks for pointing out. However, I only got a 0 byte file after
> adding the include statement.
> I am programming in parallel and my matrix is created using
> MatCreateMPIAIJ. Did I missed out some commands?
> PetscViewer viewer
> call  PetscViewerCreate(MPI_COMM_WORLD,viewer,ierr)
> Thank you very much.
> Regards.
> Barry Smith wrote:
>>   Likely you forgot to #include "finclude/petscviewer.h" in the
>> Fortran subroutine that
>> is doing this stuff.
>> On May 25, 2008, at 5:43 AM, Ben Tay wrote:
>>> Hi,
>>> I have an old serial code and a newer parallel code. The new
>>> parallel code is converted from the old serial code. However, due
>>> to numerous changes, the answers from the new code now differs
>>> from the old one after the 1st step. What is the best way to
>>> compare the matrices from the 2 different code?
>>> I guess the most direct mtd is to use MatView to store the matrix
>>> in a ACSII file and spot the difference between the 2 files.
>>> However, I can't seem to get it right. What I did is:
>>> PetscViewer viewer
>>> call  PetscViewerCreate(PETSC_COMM_SELF,viewer,ierr)
>>> call PetscViewerASCIIOpen(PETSC_COMM_SELF, "matrix.txt",viewer,ierr)
>>> However, I get the error that "PetscViewer viewer" has syntax
>>> error. Hope you can help me out.
>>> Regards
