Comparing matrices between 2 different codes and viewing of matrix
Ben Tay zonexo at gmail.com
Tue May 27 05:57:08 CDT 2008
Hi Barry,
Thanks for pointing out. However, I only got a 0 byte file after adding
the include statement.
I am programming in parallel and my matrix is created using
MatCreateMPIAIJ. Did I missed out some commands?
PetscViewer viewer
call  PetscViewerCreate(MPI_COMM_WORLD,viewer,ierr)
call MatView(A_mat_uv,viewer,ierr)
call PetscViewerASCIIOpen(MPI_COMM_WORLD, "matrix.txt",viewer,ierr)
call PetscViewerDestroy(viewer,ierr)
Thank you very much.
Regards.
Barry Smith wrote:
>    Likely you forgot to #include "finclude/petscviewer.h" in the
> Fortran subroutine that
> is doing this stuff.
> On May 25, 2008, at 5:43 AM, Ben Tay wrote:
>> Hi,
>> I have an old serial code and a newer parallel code. The new parallel
>> code is converted from the old serial code. However, due to numerous
>> changes, the answers from the new code now differs from the old one
>> after the 1st step. What is the best way to compare the matrices from
>> the 2 different code?
>> I guess the most direct mtd is to use MatView to store the matrix in
>> a ACSII file and spot the difference between the 2 files. However, I
>> can't seem to get it right. What I did is:
>> PetscViewer viewer
>> call  PetscViewerCreate(PETSC_COMM_SELF,viewer,ierr)
>> call PetscViewerASCIIOpen(PETSC_COMM_SELF, "matrix.txt",viewer,ierr)
>> However, I get the error that "PetscViewer viewer" has syntax error.
>> Hope you can help me out.
>> Regards
