mesh ordering and partition
    Matthew Knepley
    knepley at gmail.com
    Fri May 16 11:19:57 CDT 2008
On Fri, May 16, 2008 at 10:47 AM, Gong Ding <gdiso at ustc.edu> wrote:
> Hi,
> I am studying the parallel programming, using libmesh/petsc as an excellent
> example.
> I have some questions about the partition and mesh ordering.
> It seems libmesh does not reorder the mesh nodes. It only calls metis to
> partition the mesh, and
> uses original node order to build the matrix. I wonder if a bad mesh
> ordering may cause low efficency
> of ILU preconditioner. However, If I did RCM ordering to the mesh, the
> node's order may conflict with
> contiguous index set int the subdomain partitioned by metis. How should I
> balance the ordering (to reduce filling)
> and partition (to reduce communication)? any good ideas?
I think, if you are using the serial PETSc ILU, you should just use a
MatOrdering,
which can be done from the command line:
  -pc_type ilu -pc_factor_mat_ordering_type rcm
which I tested on KSP ex2.
  Matt
> Regards,
> Gong Ding
experiments is infinitely more interesting than any results to which
their experiments lead.
-- Norbert Wiener
