Q. of multi-componet system and data from input file
    tsjb00
    tsjb00 at hotmail.com
    Tue May 13 10:14:05 CDT 2008
Many thanks for your help!
> From: bsmith at mcs.anl.gov
> To: petsc-users at mcs.anl.gov
> Subject: Re: Q. of multi-componet system and data from input file
> Date: Mon, 12 May 2008 19:07:33 -0500
> On May 12, 2008, at 1:59 PM, tsjb00 wrote:
>> Hi, there! I am a beginner of PETSc and I have some questions about
>> using PETSc to solve for a multi-componet system. The code is
>> supposed to be applicable to different systems, where number of
>> components, properties of components ,etc. would be input for the
>> program.
>> Say I define DA with dof=number of components = nc, number of grid
>> in x,y,z = nx,ny,nz respectively. When I use DA related functions,
>> it seems that by default the data objects (vectors, arrays, etc.)
>> would be of nx*ny*nz*nc. However, some physical variables are
>> independent of specific components, which means I need to handle
>> data objects of nx*ny*nz*integral. My questions are:
>> Does PETSc include tools or examples to deal with such problems?
>> If not, how can I make sure the 'nx*ny*nz*any integral' data objects
>> are distributed over the nodes in a way defined by DA? I am using
>> PETSc_Decide for partitioning right now. I would prefer that at
>> least the number of processors be flexible.
>     I do not understand your question but here is a stab at it. For
> each different nc you need in your code you simply create a different
> DA. For example if you have
> two fields you want together and also have three fields together you
> would create one DA for the 2 dof and one for the 3 dof. Adding a
> couple more DA's won't take
> much memory or time.
>     You can use DAVecGetArray() to access the values for a fixed dof,
> if sometimes you want nc to be different for different runs within the
> same
> loops you can use DAVecGetArrayDOF(). You access values via x[k][j][i]
> [l] where l goes from 0 to dof-1 for the dof that you used to create
> the DA.
>     Barry
>> I need to read in a property f(x,y,z) from a data file and then
>> distribute the data across different processors. Any suggestions on
>> this would be appreciated. My concern is that if I use MPI_Send/
>> Receive, the data to be transferred might correspond to
>> discontinuous indices due to the partitioning.
>> Many thanks in advance!
>> BJ
>> _________________________________________________________________
>> MSN 中文网,最新时尚生活资讯,白领聚集门户。
>> http://cn.msn.com
Windows Live Photo gallery 数码相机的超级伴侣,轻松管理和编辑照片,还能制作全景美图!
http://get.live.cn/product/photo.html
