Number of iterations of the CG method
    Barry Smith
    bsmith at mcs.anl.gov
    Fri Jan 25 19:40:33 CST 2008
   With PETSc to do this simply run with the option -ksp_monitor.
   The first few residual norms should be VERY similar; eventually
since it is likely the order of the floating
point operations is different between your code and PETSc they will
eventually be a bit different. But you should
see the exact, or almost the exact same number of iterations.
    Barry
On Jan 25, 2008, at 6:38 PM, Mads Hoel wrote:
> Do you use the same starting vector in both cases? You can look at
> the residual, check it after each iteration. You can also try to let
> PETSc use the same convergence test/monitor.
> On Sat, 26 Jan 2008 00:35:04 +0100, Matthew Knepley
> <knepley at gmail.com> wrote:
>> This sounds like the stopping criteria are different.
>>  Matt
>> On Jan 25, 2008 5:28 PM, USUARIO INICIAL <ronanrmo at ig.com.br> wrote:
>>> I have a conjugate gradient implemented in C without Petsc and
>>> when I
>>> solve the linear system of my problem (an elliptic pde) it converges
>>> with something about 270 iterations. But with Petsc (ksp_type cg
>>> pc_type none) the same linear system converges with 510 iterations.
>>> Do someone have any idea why is that happenning?
>>> I already checked the matrix and they are equal. The results are
>>> quite
>>> close and I set the same tolerance to both methods (setting rtol on
>>> petsc to a very small number, to use only atol). And besides the
>>> number of iterations, the time spent by petsc is not much more than
>>> the other method.
>>> Thanks,
>>> Ronan
>>> I'm sorry, I dont know english very well, I did the best I could.
> Mads Hoel
