whether do I need to consider the symmetric preconditioner when using CG?
Wed Jan 16 11:23:25 CST 2008
    Yujie,
      I now understand the reason for your question. CG can be
implemented with right, left or split preconditioner and in
ALL three cases it is still a symmetric implementation of CG! All give
similar convergence rates.
     The largest effect of left, right or split is in stopping
criteria; right preconditioning always uses the TRUE residual
norm to determine convergence || b - A x||, left preconditioning using
|| B(b - Ax) ||. You can use
-ksp_norm_type unpreconditioned  with left preconditioner or natural
norm. You can see the code KSPSolve_CG
for exact details.
    Barry
On Jan 16, 2008, at 11:15 AM, Yujie wrote:
> Dear Lisandro:
> From PETSc manual, I know KSPCG only supports left preconditioning.
> However, I want to know whether does this affect the performance of
> preconditioned CG? The main problem is that it should be better to
> generate a symmetric preconditioned operator for CG method. However,
> Left preconditioner should have some difficulty to get such
> operator? Do you have any testings about it regarding left, split
> and right preconditinoers and CG realization in PETSc? thanks a lot.
> Regards,
> Yujie
> On 1/16/08, Yujie <recrusader at gmail.com> wrote:
> > hi, everyone
> > I know there are three types of preconditioners, that is left,
> split and
> > right preconditioners? When I use CG method in PETSc, whether do I
> need to
> > consider select one type of preconditioner? Whether do different
> types
> > affect the performance of preconditioned CG? thanks a lot.
> > Regards,
> > Yujie
> Lisandro Dalcín
> Centro Internacional de Métodos Computacionales en Ingeniería (CIMEC)
> Instituto de Desarrollo Tecnológico para la Industria Química (INTEC)
> Consejo Nacional de Investigaciones Científicas y Técnicas (CONICET)
> PTLC - Güemes 3450, (3000) Santa Fe, Argentina
> Tel/Fax: +54-(0)342-451.1594
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20080116/8677c3da/attachment.htm>
