whether do I need to consider the symmetric preconditioner when using CG?
Yujie
recrusader at gmail.com
Wed Jan 16 11:15:43 CST 2008
Dear Lisandro:
>From PETSc manual, I know KSPCG only supports left preconditioning. However,
I want to know whether does this affect the performance of preconditioned
CG? The main problem is that it should be better to generate a symmetric
preconditioned operator for CG method. However, Left preconditioner should
have some difficulty to get such operator? Do you have any testings about it
regarding left, split and right preconditinoers and CG realization in
PETSc? thanks a lot.
Yujie
> On 1/16/08, Yujie <recrusader at gmail.com> wrote:
> > hi, everyone
> > I know there are three types of preconditioners, that is left, split and
> > right preconditioners? When I use CG method in PETSc, whether do I need
> to
> > consider select one type of preconditioner? Whether do different types
> > affect the performance of preconditioned CG? thanks a lot.
> > Regards,
> > Yujie
> Lisandro Dalcín
> Centro Internacional de Métodos Computacionales en Ingeniería (CIMEC)
> Instituto de Desarrollo Tecnológico para la Industria Química (INTEC)
> Consejo Nacional de Investigaciones Científicas y Técnicas (CONICET)
> PTLC - Güemes 3450, (3000) Santa Fe, Argentina
> Tel/Fax: +54-(0)342-451.1594
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20080116/0aa10d39/attachment.htm>
