Error when using MKL 10.0.5.025
Matthew Knepley
knepley at gmail.com
Mon Dec 1 08:33:50 CST 2008
Perhaps you forgot to update your LD_LIBRARY_PATH when running the first
one.
Matt
On Mon, Dec 1, 2008 at 5:50 AM, Ben Tay <zonexo at gmail.com> wrote:
> Hi,
> I met with some problems when using the MKL 10.0.5.025. My PETSc was
> compiled using --with-shared=0. However, after compilation, when I run some
> of the tests such as ex1f and ex2f, I got the error:
> ./ex2f: error while loading shared libraries: libmkl_lapack.so: cannot open
> shared object file: No such file or directory
> I thought I had specified to use static. My command to compile is :
> ./config/configure.py --with-vendor-compilers=intel --with-x=0
> --with-hypre-dir=/home/svu/g0306332/lib/hypre --with-debugging=0
> --with-batch=1 --with-mpi-dir=/app1/mvapich/current/ --with-mpi-shared=0
> --with-shared=0 --with-blas-lapack-dir=/opt/intel/cmkl/
> 10.0.5.025/lib/em64t
> However, if I use back MKL 8.1.1, with similar command, then there's no
> such problem.
> Hope you can help. Thanks!
> Yours sincerely,
> Ben Tay
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20081201/0948d28f/attachment.htm>
