Error when using MKL 10.0.5.025
Ben Tay
zonexo at gmail.com
Mon Dec 1 05:50:54 CST 2008
I met with some problems when using the MKL 10.0.5.025. My PETSc was
compiled using --with-shared=0. However, after compilation, when I run
some of the tests such as ex1f and ex2f, I got the error:
./ex2f: error while loading shared libraries: libmkl_lapack.so: cannot
open shared object file: No such file or directory
I thought I had specified to use static. My command to compile is :
./config/configure.py --with-vendor-compilers=intel --with-x=0
--with-hypre-dir=/home/svu/g0306332/lib/hypre --with-debugging=0
--with-batch=1 --with-mpi-dir=/app1/mvapich/current/ --with-mpi-shared=0
--with-shared=0 --with-blas-lapack-dir=/opt/intel/cmkl/10.0.5.025/lib/em64t
However, if I use back MKL 8.1.1, with similar command, then there's no
such problem.
Hope you can help. Thanks!
Yours sincerely,
Ben Tay
