small space step lead to floating point exception
Shengyong lua.byhh at gmail.com
Mon Aug 25 07:11:37 CDT 2008
Barry,
Thank you very much!
On Mon, Aug 25, 2008 at 1:19 AM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>   You need to determine where the floating point exception occurs. On some
> computers
> this is easy, just run the code in the debugger and use the debugger option
> to trap floating
> point exceptions.  Unfortunately this may not always be possible: in that
> case I would
> start with running with -info -snes_monitor -ksp_monitor to see what is
> happening before
> the floating point exception that is causing the difficulty.
>   Barry
> On Aug 24, 2008, at 7:18 AM, Shengyong wrote:
>  Hi,
>> Does anyone happen to meet such convergency problem?  I have implemented a
>> petsc solver
>> to simulate driven cavity flow problem. I use petsc to solve the poisson
>> equation. When I set the space step
>> dx = 1 or 0.01, it works fine. However, when i tried to simulate a meso
>> scale problem, i set dx = 0.0001, dt = 0.00001.
>> I got a error : floating point execption..
>> Does anyone point me out how to solve this problem ?
>> ong
>> Solidification  Simulation Lab,
>> State Key Lab of  Mould & Die Technology,
>> Huazhong Univ. of Sci. & Tech. China
Pang Shengyong
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20080825/e6ec99b2/attachment.htm>
