MatGetVecs and MATMFFD
Boyce Griffith
griffith at courant.nyu.edu
Thu Aug 21 11:23:49 CDT 2008
Hi, Lisandro --
Is there any way to associate a context with a MFFD matrix? It seems like
the Otherwise, it seems like the implementation of MatGetVecs would need
to use global variables in order to create the appropriate vectors.
Or is it possible to get access to the solution and right-hand-side
vectors used by an associated SNES and use VecDuplicate on them?
-- Boyce
On Thu, 21 Aug 2008, Lisandro Dalcin wrote:
> On Thu, Aug 21, 2008 at 9:01 AM, Boyce Griffith
> <griffith at courant.nyu.edu> wrote:
>> Hi, Folks --
>> I am using a home-grown "multi-Vec" (i.e., vector of vectors) implementation
>> with a PETSc nonlinear solver. I'd like to be able to use PETSc's
>> matrix-free Jacobian with this solver along with a PCCOMPOSITE
>> preconditioner; however, it seems like I need to override the default
>> implementation of MatGetVecs in order to get this to work.
>> Is there a kosher way to do this?
> You can use MatShellSetOperation() and set the operation
> MATOP_GET_VECS. Despite the name, that function can let you set/change
> the implementation of Mat operations for any matrix type. Try to make
> the call to MatShellSetOperation() in the Jacobian routine and let me
> know if you have trouble.
>> Thanks,
>> -- Boyce
> Lisandro Dalcín
> Centro Internacional de Métodos Computacionales en Ingeniería (CIMEC)
> Instituto de Desarrollo Tecnológico para la Industria Química (INTEC)
> Consejo Nacional de Investigaciones Científicas y Técnicas (CONICET)
> PTLC - Güemes 3450, (3000) Santa Fe, Argentina
> Tel/Fax: +54-(0)342-451.1594
