MatGetVecs and MATMFFD
Lisandro Dalcin
dalcinl at gmail.com
Thu Aug 21 11:00:51 CDT 2008
On Thu, Aug 21, 2008 at 9:01 AM, Boyce Griffith
<griffith at courant.nyu.edu> wrote:
> Hi, Folks --
> I am using a home-grown "multi-Vec" (i.e., vector of vectors) implementation
> with a PETSc nonlinear solver. I'd like to be able to use PETSc's
> matrix-free Jacobian with this solver along with a PCCOMPOSITE
> preconditioner; however, it seems like I need to override the default
> implementation of MatGetVecs in order to get this to work.
> Is there a kosher way to do this?
You can use MatShellSetOperation() and set the operation
MATOP_GET_VECS. Despite the name, that function can let you set/change
the implementation of Mat operations for any matrix type. Try to make
the call to MatShellSetOperation() in the Jacobian routine and let me
know if you have trouble.
> Thanks,
> -- Boyce
Lisandro Dalcín
Centro Internacional de Métodos Computacionales en Ingeniería (CIMEC)
Instituto de Desarrollo Tecnológico para la Industria Química (INTEC)
Consejo Nacional de Investigaciones Científicas y Técnicas (CONICET)
PTLC - Güemes 3450, (3000) Santa Fe, Argentina
Tel/Fax: +54-(0)342-451.1594
