Does petsc exploit the symmetric property of matrix?
Shengyong
lua.byhh at gmail.com
Fri Aug 15 21:33:07 CDT 2008
Hi, hong
Thanks very much!
Best Regards,
On Fri, Aug 15, 2008 at 10:28 PM, Hong Zhang <hzhang at mcs.anl.gov> wrote:
> Shengyong,
> On Fri, 15 Aug 2008, berry wrote:
> Hi,
>> I am totally a newbie to petsc. Previously I use laspack library for my
>> linear solver. Now I decide to transfer to Petsc for our simulation code.
>> I have a huge sparse matrix with 3million*3million with 21 million no zero
>> elements. The matrix is symmetric, so the non zero element of upper
>> triangular matrix
>> is only 12 million. And matrix format is Yale Space Matrix format.
>> However,
>> I have not seen any indicative parmater for matrix symmetry property in
>> MatCreateSeqAIJWithArrays() function. The manual says:
>> PetscErrorCode PETSCMAT_DLLEXPORT MatCreateSeqAIJWithArrays(MPI_Comm
>> comm,PetscInt m,PetscInt n,PetscInt* i,PetscInt*j,PetscScalar *a,Mat
>> *mat)
>> http://www-unix.mcs.anl.gov/petsc/petsc-2/snapshots/petsc-current/docs/manualpages/Sys/MPI_Comm.html#MPI_Comm
>> Input Parameters
>> *comm<
>> http://www-unix.mcs.anl.gov/petsc/petsc-2/snapshots/petsc-current/docs/manualpages/Sys/comm.html#comm
>> *- must be an MPI communicator of
>> size<
>> http://www-unix.mcs.anl.gov/petsc/petsc-2/snapshots/petsc-current/docs/manualpages/Sys/size.html#size
>> >1
>> *m *- number of rows
>> *n *- number of columns
>> *i *- row indices
>> *j *
>> *a *
>> Can petsc exploit any symmetric proptery of a given matrix? How could I
>> Set
>> it to be symmetry one ?
> You can use MATSBAIJ matrix format
> (see
> http://www-unix.mcs.anl.gov/petsc/petsc-as/snapshots/petsc-current/docs/manualpages/Mat/MATSBAIJ.html
> Using MATSBAIJ saves half of storage space for original sparse matrix.
> However,
> it is not as efficient as MATAIJ for some matrix operations, e.g.,
> MatMult(), due to non-contiguous data access and additional communication
> overhead.
> Hong
>> Best Regards,
>> Pang Shengyong
>> Solidification Simulation Lab,
>> State Key Lab of Mould & Die Technology,
>> Huazhong Univ. of Sci. & Tech. China
Pang Shengyong
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20080816/11722497/attachment.htm>
