Petsc questions
Nguyen, Hung V ERDC-ITL-MS
Hung.V.Nguyen at usace.army.mil
Fri Aug 15 11:00:43 CDT 2008
Hello All,
I have question about how to write a matrix to output file in binary (or
ASCII) format.
In the test case below, the ai is original matrix and a is petsc version.
The test runs successfully to write a binary file named "matrix.mat".
However, when I rerun the test with reading matrix via "matload", then I got
the error "Unknown Mat type given: !". Please let me know how to fix it.
Thank you in advance,
-Hung
-- error at running:
yod -np 16 ./fw -ksp_type cg -pc_type bjacobi -ksp_rtol 1.0e-15 -ksp_max_it
50000
hvnguyen:sapphire18% yod -np 16 ./fw -ksp_type cg -pc_type bjacobi -ksp_rtol
1.0e-15 -ksp_max_it 50000
[10]PETSC ERROR: [9]PETSC ERROR: --------------------- Error Message
--------------------- Error Message ------------------------------------
[10]PETSC ERROR: [9]PETSC ERROR: Unknown type. Check for miss-spelling or
missing external package needed for type!
Unknown type. Check for miss-spelling or missing external package needed for
type!
[10]PETSC ERROR: [9]PETSC ERROR: Unknown Mat type given: !
---code:
! Define the a matrix.
ione = 1
ii = ncol
jj = ncol / 2
call MatCreateMPIAIJ (PETSC_COMM_WORLD, nown, nown, ng, ng,
& ii, PETSC_NULL_INTEGER, jj, PETSC_NULL_INTEGER, a, ierr)
call MatSetFromOptions (a, ierr)
do i = 1, nown
ii = npetsc(i) - 1
do j = 1, ncol
jloc = id(i, j)
if (jloc .ne. 0) then
jj = npetsc(jloc) - 1
v = ai(i, j)
call MatSetValues (a, ione, ii, ione, jj, v,
& INSERT_VALUES, ierr)
end if
end do
end do
call MatAssemblyBegin (a, MAT_FINAL_ASSEMBLY, ierr)
call MatAssemblyEnd (a, MAT_FINAL_ASSEMBLY, ierr)
! Now Write this matrix to a binary file
call PetscViewerBinaryOpen(PETSC_COMM_WORLD,'matrix.mat',
& FILE_MODE_WRITE,view,ierr)
call PetscViewerSetFormat(view,PETSC_VIEWER_BINARY_NATIVE,ierr)
call MatView(A,view,ierr)
call PetscViewerDestroy(view,ierr)
---- Test to load A matix:
!!! read matrix
call PetscViewerBinaryOpen(PETSC_COMM_WORLD,'matrix.mat', &
& FILE_MODE_READ,view,ierr)
call MatLoad(view,MPIAIJ,A,ierr)
CHKERRQ(ierr)
