problem in compiling petsc for visual c++ 2005
berry
lua.byhh at gmail.com
Wed Aug 13 03:44:56 CDT 2008
Thanks for you reply. Previously may be I did not set the cxx compiler ,
so 'make all test' produces '.a ' file. This time it produces correct '.lib'
files after the correct setting.
Best Regards,
On Wed, Aug 13, 2008 at 4:27 PM, Farshid Mossaiby <mossaiby at yahoo.com>wrote:
> Hi,
> I am not sure how to do this, but why you need it? The resulting .lib files
> can later be used in your own programs without any problems.
> Best regards,
> Farshid Mossaiby
> --- On Wed, 8/13/08, berry <lua.byhh at gmail.com> wrote:
> > From: berry <lua.byhh at gmail.com>
> > Subject: Re: problem in compiling petsc for visual c++ 2005
> > To: petsc-users at mcs.anl.gov
> > Date: Wednesday, August 13, 2008, 12:50 PM
> > Hi,
> > How can you change the Linker to VC 2008 's link.exe?
> > I configured the
> > script successfuly. But my linker option (PETSc generated)
> > is /usr/bin/ar. Below is part of the scratch configure
> > results.
> > Compilers:
> > C Compiler:
> > /home/pangshengyong/soft/petsc-2.3.3-p13/bin/win32fe/win32
> > fe cl --nodetect -wd4996 -MT
> > C++ Compiler:
> > fe cl --nodetect -GR -GX -EHsc -MT -O2 -Zm200 -TP
> > Fortran Compiler:
> > fe ifort --nodetect -MT -O3 -QxW -fpp
> > *Linkers:
> > Static linker: /usr/bin/ar cr*
> > PETSc:
> > PETSC_ARCH: windows_VC
> > PETSC_DIR: /home/pangshengyong/soft/petsc-2.3.3-p13
> > ** Now build and test the libraries with "make all
> > test"
> > Clanguage: C
> > Scalar type:real
> > PETSc shared libraries: disabled
> > PETSc dynamic libraries: disabled
> > BLAS/LAPACK:
> > -L/home/pangshengyong/soft/petsc-2.3.3-p13/externalpackages/fblasla
> > pack/windows_VC
> > slapack/windows_VC -lflapack
> > packages/fblaslapack/windows_VC
> > nalpackages/fblaslapack/windows_VC -lfblas
> > Regards,
> > On Wed, Aug 13, 2008 at 4:06 PM, Farshid Mossaiby
> > > Hi,
> > > They are .lib files.
> > > Best regards,
> > > Farshid Mossaiby
> > visual c++ 2005
> > > > Date: Wednesday, August 13, 2008, 11:39 AM
> > > > Hi, Farshid
> > > > Thanks for you suggestions. Can you tell me the
> > surfix of
> > > > your compiled
> > > > library is .a or .lib?
> > > > On Wed, Aug 13, 2008 at 2:44 PM, Farshid Mossaiby
> > > > > Hi,
> > > > > I have built Petsc a lot of times with VC++
> > 2008
> > > > Express edition and
> > > > > Cygwin. I used to run
> > C:\Cygwin\Cygwin.bat,
> > > > and had no problem.
> > > > > I just looked into the batch file, and it
> > contains:
> > > > > @echo off
> > > > > C:
> > > > > chdir C:\Cygwin\bin
> > > > > bash --login -i
> > > > > I am not sure what '-i' in bash
> > parameters
> > > > mean, but it may help you.
> > > > > Anyway, I still recommend you running the
> > batch file
> > > > itself.
> > > > > Best regards,
> > > > > Farshid Mossaiby
> > > > > --- On Tue, 8/12/08, berry
> > for
> > > > visual c++ 2005
> > > > > > Date: Tuesday, August 12, 2008, 9:49 PM
> > > > > > Hi, Satish
> > > > > > Sorry for my vague reply.
> > > > > > I just use 'bash' not 'bash
> > > > --login'. With
> > > > > > 'bash' only, the configure
> > script
> > > > > > can not find 'mkdir' and
> > 'sed'
> > > > command, as
> > > > > > you kindly points me out.
> > > > > > Then I try this utilities:
> > 'usr/bin/run.exe
> > > > -ls'
> > > > > > to open a xterm window. I
> > > > > > Successed. In this window, I can find
> > > > 'mkdir' and
> > > > > > 'sed' plus visual c++'s
> > > > > > 'cl.exe' and intel fortran
> > 's
> > > > > > 'ifort.exe' now.
> > > > > > After that, I do configure petsc again
> > with
> > > > > > './config/configure.py '( I can
> > > > > > not remember other paramters for mpich
> > , lapack,
> > > > blas,
> > > > > > winfe cl , winfe
> > > > > > ifort and hypre now, but I follow the
> > exact
> > > > guidence from
> > > > > > petsc official
> > > > > > website).
> > > > > > However, after several minutes's
> > > > configuration, petsc
> > > > > > configuration script
> > > > > > still CRASHED with no error prompt on
> > screen. It
> > > > just tell
> > > > > > me to send the
> > > > > > config.log file to developers. Right
> > now I am not
> > > > in my
> > > > > > office, tomorrow I
> > > > > > will send the config.log file to
> > corresponding
> > > > email
> > > > > > address.
> > > > > > Hope this time you can understand what
> > I say.
> > > > > > Thanks for you help!
> > > > > > On Tue, Aug 12, 2008 at 10:43 PM,
> > Satish Balay
> > > > > > <balay at mcs.anl.gov> wrote:
> > > > > > > On Tue, 12 Aug 2008, berry wrote:
> > > > > > > > Thanks, I have already
> > logged into the
> > > > cygwin
> > > > > > from VC command prompt.
> > > > > > > What does this mean? do you now
> > have mkdir
> > > > and sed in
> > > > > > your path?
> > > > > > > If not - redo VC cmd prompt - and
> > 'bash
> > > > > > --login' - and let us know if:
> > > > > > > - mkdir & sed are in your PATH
> > > > > > > which sed
> > > > > > > which mkdir
> > > > > > > - now configure is successful or
> > not..
> > > > > > > Satish
> > > > > > Pang Shengyong
> > > > > > Solidification Simulation Lab,
> > > > > > State Key Lab of Mould & Die
> > Technology,
> > > > > > Huazhong Univ. of Sci. & Tech.
> > China
> > > > Pang Shengyong
> > > > State Key Lab of Mould & Die Technology,
> > > > Huazhong Univ. of Sci. & Tech. China
> > Pang Shengyong
Pang Shengyong
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20080813/610e384c/attachment.htm>
