KSPSetNullSpace and CG for singular systems
Shao-Ching Huang schuang at ats.ucla.edu
Sun Aug 3 20:23:47 CDT 2008
Hi Barry:
Thanks you for your suggestions. Now both sequential and parallel
cases work when I use CG.
Shao-Ching
On Fri, Aug 01, 2008 at 08:56:23PM -0500, Barry Smith wrote:
>    It is not the null space that is the problem.
>    You are right to try the shift but
> 1) first run on one process using -pc_type icc -ksp_type cg -
> pc_factor_shift_positive_definite
> this will keep increasing the shift until it produces a positive-
> definite preconditioner.
> Run also with -ksp_view to confirm that it is using all the options you
> provided. (you can run with -help to
> see the option names)
> 2) If you have the sequential converging then use -pc_type bjacobi -
> sub_pc_type icc -pc_factor_shift_positive_definite
> Barry
> On Aug 1, 2008, at 7:52 PM, Shao-Ching Huang wrote:
>> Hi,
>> I am trying to use CG to solve a singular systems (i.e. Poisson
>> equation with periodic conditions on all boundaries).
>> The code works when I use GMRES, but it diverges when I switch CG.
>> Since the null space is a constant vector, in the code I have:
>>   KSP ksp;
>>   MatNullSpace nullspace;
>>   MatNullSpaceCreate(MPI_COMM_WORLD, PETSC_TRUE, 0, PETSC_NULL,
>> &nullspace);
>>   KSPSetNullSpace(ksp, nullspace);
>>   MatNullSpaceRemove(nullspace, f->p_rhs, PETSC_NULL);
>>   KSPSetFromOptions(ksp);
>>   KSPSetUp(ksp);
>>   KSPSolve(ksp, f->p_rhs, f->phi);
>> [f->p_rhs is the RHS vector. f->phi is the solution vector.]
>> When I use "-ksp_type gmres", it converges (shown by -ksp_monitor).
>> However, when I switch to "-ksp_type cg", it diverges.
>> In this case (cg), "-ksp_converged_reason" says:
>>  Linear solve did not converge due to DIVERGED_INDEFINITE_PC
>> iterations 1
>> I also try adding "-sub_pc_factor_shift_nonzero 0.0000000001" but the
>> CG case still fails.
>> Am I missing some step in handling the null space when using CG?
>> Thanks,
>> Shao-Ching Huang
