KSPSetNullSpace and CG for singular systems
Barry Smith
bsmith at mcs.anl.gov
Fri Aug 1 20:56:23 CDT 2008
It is not the null space that is the problem.
You are right to try the shift but
1) first run on one process using -pc_type icc -ksp_type cg -
pc_factor_shift_positive_definite
this will keep increasing the shift until it produces a positive-
definite preconditioner.
Run also with -ksp_view to confirm that it is using all the options
you provided. (you can run with -help to
see the option names)
2) If you have the sequential converging then use -pc_type bjacobi -
sub_pc_type icc -pc_factor_shift_positive_definite
Barry
On Aug 1, 2008, at 7:52 PM, Shao-Ching Huang wrote:
> Hi,
> I am trying to use CG to solve a singular systems (i.e. Poisson
> equation with periodic conditions on all boundaries).
> The code works when I use GMRES, but it diverges when I switch CG.
> Since the null space is a constant vector, in the code I have:
> KSP ksp;
> MatNullSpace nullspace;
> MatNullSpaceCreate(MPI_COMM_WORLD, PETSC_TRUE, 0, PETSC_NULL,
> &nullspace);
> KSPSetNullSpace(ksp, nullspace);
> MatNullSpaceRemove(nullspace, f->p_rhs, PETSC_NULL);
> KSPSetFromOptions(ksp);
> KSPSetUp(ksp);
> KSPSolve(ksp, f->p_rhs, f->phi);
> [f->p_rhs is the RHS vector. f->phi is the solution vector.]
> When I use "-ksp_type gmres", it converges (shown by -ksp_monitor).
> However, when I switch to "-ksp_type cg", it diverges.
> In this case (cg), "-ksp_converged_reason" says:
> Linear solve did not converge due to DIVERGED_INDEFINITE_PC
> iterations 1
> I also try adding "-sub_pc_factor_shift_nonzero 0.0000000001" but the
> CG case still fails.
> Am I missing some step in handling the null space when using CG?
> Thanks,
> Shao-Ching Huang
