Zero Pivot Row in LU Factorization
Matthew Knepley
knepley at gmail.com
Sun Nov 25 13:02:10 CST 2007
On Nov 25, 2007 12:54 PM, Tim Stitt <timothy.stitt at ichec.ie> wrote:
> Hi all,
> Can anyone suggest ways of overcoming the following pivot error I keep
> receiving in my PETSc code during a KSPSolve().
> [1]PETSC ERROR: Detected zero pivot in LU factorization
> see
> http://www.mcs.anl.gov/petsc/petsc-as/documentation/troubleshooting.html#ZeroPivot!
> [1]PETSC ERROR: Zero pivot row 1801 value 0.00102826 tolerance
> 0.00165189 * rowsum 1.65189e+09!
> From checking the documentation....the error is in row 1801, which
> means it is most likely not a matrix assembly issue?
> I tried the following prior to the solve with no luck either.....
> call KSPGetPC(ksp,pc,error)
> call PCFactorSetShiftNonzero(pc,PETSC_DECIDE,error)
I bet you are shifting the Block-Jacobi PC, not the LU PC which is the
subsolver.
Matt
> Is there anything else I can try?
> Thanks,
> Tim.
> Dr. Timothy Stitt <timothy_dot_stitt_at_ichec.ie>
> HPC Application Consultant - ICHEC (www.ichec.ie)
> Dublin Institute for Advanced Studies
> 5 Merrion Square - Dublin 2 - Ireland
> +353-1-6621333 (tel) / +353-1-6621477 (fax)
experiments is infinitely more interesting than any results to which
their experiments lead.
-- Norbert Wiener
