Zero Pivot Row in LU Factorization
Tim Stitt timothy.stitt at ichec.ie
Sun Nov 25 12:54:54 CST 2007
Hi all,
Can anyone suggest ways of overcoming the following pivot error I keep
receiving in my PETSc code during a KSPSolve().
[1]PETSC ERROR: Detected zero pivot in LU factorization
see
http://www.mcs.anl.gov/petsc/petsc-as/documentation/troubleshooting.html#ZeroPivot!
[1]PETSC ERROR: Zero pivot row 1801 value 0.00102826 tolerance
0.00165189 * rowsum 1.65189e+09!
 From checking the documentation....the error is in row 1801, which
means it is most likely not a matrix assembly issue?
I tried the following prior to the solve with no luck either.....
call KSPGetPC(ksp,pc,error)
call PCFactorSetShiftNonzero(pc,PETSC_DECIDE,error)
Is there anything else I can try?
Tim.
Dr. Timothy Stitt <timothy_dot_stitt_at_ichec.ie>
HPC Application Consultant - ICHEC (www.ichec.ie)
Dublin Institute for Advanced Studies
5 Merrion Square - Dublin 2 - Ireland
+353-1-6621333 (tel) / +353-1-6621477 (fax)
