Parallel ISCreateGeneral()
Matthew Knepley
knepley at gmail.com
Sun Nov 18 12:01:50 CST 2007
On Nov 18, 2007 11:52 AM, Tim Stitt <timothy.stitt at ichec.ie> wrote:
> Matt,
> It is in setup for MatLUFactorSymbolic() and MatLUFactorNumeric() calls
> which require index sets. I have distributed my rows across the
> processes and now just a bit confused about the arguments to the
> ISCreateGeneral() routine to set up the IS sets used by the Factor
> routines in parallel.
> So my basic question is what in general is the length and integers that
> get passed to ISCreateGeneral() when doing this type of calculation in
> parallel? Are they local index values (0..#rows on process-1) or do they
> refer to the distributed indices of the global matrix?
To be consistent, these would be local sizes and global numberings. However,
I am not sure why you would be doing this. I do not believe any of the parallel
LU packages accept an ordering from the user (they calculate their own),
and I would really only use them from a KSP (or PC at the least).
Matt
> Tim.
> Matthew Knepley wrote:
> > On Nov 18, 2007 11:34 AM, Tim Stitt <timothy.stitt at ichec.ie> wrote:
> >> OK..so I should be using the aggregate length returned by
> >> MatGetOwnershipRange() routine?
> > If you are using it to permute a Mat, yes.
> > Matt
> >> Thanks Matt for you help.
> >>> IS are not really parallel, so all the lengths, etc. only refer to local things.
> >>> Matt
> >>> On Nov 18, 2007 11:22 AM, Tim Stitt <timothy.stitt at ichec.ie> wrote:
> >>>> Hi all,
> >>>> Just wanted to know if the "the length of the index set" for a call to
> >>>> ISCreateGeneral() in a parallel code, is a global length, or the length
> >>>> of the local elements on each process?
> >>>> Thanks,
> >>>> Tim.
> >>>> Dr. Timothy Stitt <timothy_dot_stitt_at_ichec.ie>
> >>>> HPC Application Consultant - ICHEC (www.ichec.ie)
> >>>> Dublin Institute for Advanced Studies
> >>>> 5 Merrion Square - Dublin 2 - Ireland
> >>>> +353-1-6621333 (tel) / +353-1-6621477 (fax)
experiments is infinitely more interesting than any results to which
their experiments lead.
-- Norbert Wiener
