Nonzeros of SBAIJ
Hong Zhang
hzhang at mcs.anl.gov
Wed Nov 14 10:17:28 CST 2007
> Dear all
> I allocated the memory exactly with symbolic computation, and tried
> preallocation on AIJ and SBAIJ, it works well for AIJ, no additional
> allocaiton is needed in assembly... then I did it on SBAIJ ( nonzeros of
> upper triangular part + 1), the performance is much worse , it seems that
> memory allocation was still needed... does anyone have such problem before?
May I have the segment of your code that implements the memory allocation?
I'll test it and see what is the problem.
BTW, you may send this type of request to petsc-maint at mcs.anl.gov
instead of petsc-users.
Hong
> Thank you
> Best regards
> Zhifeng Sheng
