multi core os x machines
Randall Mackie
randy at geosystem.us
Tue Nov 13 11:01:47 CST 2007
We have a 64 node cluster, each node being a quad core Intel Xeon chip,
so we have a total of 256 cpus. i'm not quite sure of the chip architecture
and the memory paths.
With infiniband, each cpu can go at full 100% during a PETSc execution.
The key for us was the infiniband and the special mpi that is tuned
for the infiniband - without them, performance was much worse (ie, using
mpich).
Randy M.
Barry Smith wrote:
> It depends on how the memory is connected to the individual cores or CPUS;
> for example the AMD has a different approach than Intel. If the
> different processors/cores
> have SEPERATE paths to memory then you will not see this terrible effect.
> Barry
> On Nov 13, 2007, at 10:23 AM, Gideon Simpson wrote:
>> This is also true for a multi-processor machine, or its unique to
>> multi-core machines?
>> -gideon
>> On Nov 13, 2007, at 11:14 AM, Barry Smith wrote:
>>> Not possible. The problem is that with one process it uses all the
>>> memory
>>> bandwidth, when you change to use 2 processes (2 cores) each core
>>> now gets only half the memory bandwidth and hence essentially half
>>> the speed.
>>> Barry
>>> Barry
>>> On Nov 13, 2007, at 10:06 AM, Gideon Simpson wrote:
>>>> Has anyone had any success in getting good performance on multi-core
>>>> intel os x machines with petsc? What's the right way to get MPICH
>>>> up and running for such a thing?
>>>> -Gideon Simpson
>>>> Department of Applied Physics and Applied Mathematics
>>>> Columbia University
Randall Mackie
GSY-USA, Inc.
PMB# 643
2261 Market St.,
San Francisco, CA 94114-1600
Tel (415) 469-8649
Fax (415) 469-5044
California Registered Geophysicist
License No. GP 1034
