multi core os x machines
Tue Nov 13 10:31:05 CST 2007
   It depends on how the memory is connected to the individual cores
or CPUS;
for example the AMD has a different approach than Intel. If the
different processors/cores
have SEPERATE paths to memory then you will not see this terrible
effect.
    Barry
On Nov 13, 2007, at 10:23 AM, Gideon Simpson wrote:
> This is also true for a multi-processor machine, or its unique to
> multi-core machines?
> -gideon
> On Nov 13, 2007, at 11:14 AM, Barry Smith wrote:
>>   Not possible. The problem is that with one process it uses all
>> the memory
>> bandwidth, when you change to use 2 processes (2 cores) each core
>> now gets only half the memory bandwidth and hence essentially half
>> the speed.
>>    Barry
>>    Barry
>> On Nov 13, 2007, at 10:06 AM, Gideon Simpson wrote:
>>> Has anyone had any success in getting good performance on multi-
>>> core intel os x machines with petsc?  What's the right way to get
>>> MPICH up and running for such a thing?
>>> -Gideon Simpson
>>>  Department of Applied Physics and Applied Mathematics
>>>  Columbia University
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20071113/c8adcc4a/attachment.htm>
