reordering does not work for ICC?
Barry Smith
bsmith at mcs.anl.gov
Tue Nov 6 10:29:29 CST 2007
There is no mechanism to release that extra memory. Thus it is
important to preallocate
well for large problems.
Barry
On Nov 6, 2007, at 9:29 AM, Zhifeng Sheng wrote:
> Barry Smith wrote:
>> On Nov 6, 2007, at 3:29 AM, Zhifeng Sheng wrote:
>>> Dear all
>>> I tried to reorder my the preconditioner with different reordering
>>> schema.
>>> All worked well for ILU, but does not make any difference on ICC.
>>> It seems that the reordering schema does not work for ICC at all....
>>> Is it supposed to be like this?
>> Yes, with sbaij only the upper triangular part of the matrix is
>> stored; hence reordering doesn't make sense
>> since the values needed in the reordered form are not available.
>> You can use the SeqAIJ format if you want
>> to do reorderings with the ICC.
>> Barry
>>> PS: I have a symmetric matrix and I would like to save some
>>> memory. I used SBAIJ with block=1, but some told me it's not
>>> efficient ...
>> SBAIJ with block=1 is just as efficient as AIJ! The is seperate
>> code for each block size.
>> Barry
>>> So... what can I do to save some memory on matrix and
>>> preconditioner?
>>> Thank you
>>> Best regards
>>> Zhifeng Sheng
> Thank you for your answer.
> Could you please tell me if I can first assemble the matrix with a
> sufficiently large nonzero number per row and then release the
> redundent memory after the assembly is done?
> and what does MatCompress do? I tried it on my matrix, nothing
> happened ...
> Thank you
> Best regards
