reordering does not work for ICC?
Zhifeng Sheng z.sheng at ewi.tudelft.nl
Tue Nov 6 09:29:43 CST 2007
Barry Smith wrote:
> On Nov 6, 2007, at 3:29 AM, Zhifeng Sheng wrote:
>> Dear all
>> I tried to reorder my the preconditioner with different reordering
>> schema.
>> All worked well for ILU, but does not make any difference on ICC. It
>> seems that the reordering schema does not work for ICC at all....
>> Is it supposed to be like this?
> Yes, with sbaij only the upper triangular part of the matrix is
> stored; hence reordering doesn't make sense
> since the values needed in the reordered form are not available. You
> can use the SeqAIJ format if you want
> to do reorderings with the ICC.
> Barry
>> PS: I have a symmetric matrix and I would like to save some memory. I
>> used SBAIJ with block=1, but some told me it's not efficient ...
> SBAIJ with block=1 is just as efficient as AIJ! The is seperate code
> for each block size.
> Barry
>> So... what can I do to save some memory on matrix and preconditioner?
>> Thank you
>> Best regards
>> Zhifeng Sheng
Thank you for your answer.
Could you please tell me if I can first assemble the matrix with a
sufficiently large nonzero number per row and then release the redundent
memory after the assembly is done?
and what does MatCompress do? I tried it on my matrix, nothing happened ...
Thank you
Best regards
