not enough memory?!
Fri Nov 2 08:25:59 CDT 2007
The routine which calculates ICC requested 3G, so it seems that the matrix
is too dense or large to be factored on this machine.
  Matt
On Nov 2, 2007 7:54 AM, Zhifeng Sheng <z.sheng at ewi.tudelft.nl> wrote:
> Dear all
> I have a problem for memory management.
> I implemented 3d FEM code and at this moment SeqSBAIJ is used to store
> the system matrix, then I used CG method and ICC(k) preconditioner.
> The test configuration is not very big, I succeeded in constructing the
> system matrix and construct the preconditioner. But when I need to setup
> the KSP solver, I got the error message below ( I also dumped some
> information about solver and system matrix):
> KSP Object:
>   type: cg
>   maximum iterations=10000, initial guess is zero
>   tolerances:  relative=1e-09, absolute=1e-50, divergence=10000
>   left preconditioning
> PC Object:
>   type: icc
>     ICC: 2 levels of fill
>     ICC: factor fill ratio allocated 1
>   linear system matrix = precond matrix:
>   Matrix Object:
>     type=seqsbaij, rows=435450, cols=435450
>     total: nonzeros=9470450, allocated nonzeros=21772580
>         block size is 1
> [0]PETSC ERROR: --------------------- Error Message
> [0]PETSC ERROR: Out of memory. This could be due to allocating
> [0]PETSC ERROR: too large an object or bleeding by not properly
> [0]PETSC ERROR: destroying unneeded objects.
> [0]PETSC ERROR: Memory allocated 375435120 Memory used by process 428597248
> [0]PETSC ERROR: Try running with -malloc_dump or -malloc_log for info.
> [0]PETSC ERROR: Memory requested 3108507040!
> [0]PETSC ERROR:
> [0]PETSC ERROR: Petsc Release Version 2.3.2, Patch 10, Wed Mar 28
> 19:13:22 CDT 2007 HG revision: d7298c71db7f5e767f359ae35d33cab3bed44428
> [0]PETSC ERROR: See docs/changes/index.html for recent updates.
> [0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
> [0]PETSC ERROR: See docs/index.html for manual pages.
> [0]PETSC ERROR:
> [0]PETSC ERROR: bin/main on a linux-gnu named callisto by zhifeng Fri
> Nov  2 13:26:39 2007
> [0]PETSC ERROR: Libraries linked from
> /u/01/01/zhifeng/install/lib/linux-gnu-c-debug
> [0]PETSC ERROR: Configure run at Wed Aug  8 13:46:26 2007
> [0]PETSC ERROR: Configure options --with-cc=gcc --with-fc=g77
> --download-f-blas-lapack=1 --download-mpich=1
> --prefix=/u/01/01/zhifeng/install --with-shared=0
> [0]PETSC ERROR:
> [0]PETSC ERROR: PetscMallocAlign() line 61 in src/sys/memory/mal.c
> [0]PETSC ERROR: PetscTrMallocDefault() line 194 in src/sys/memory/mtr.c
> [0]PETSC ERROR: PetscFreeSpaceGet() line 14 in src/mat/utils/freespace.c
> [0]PETSC ERROR: MatICCFactorSymbolic_SeqSBAIJ() line 1648 in
> src/mat/impls/sbaij/seq/sbaijfact2.c
> [0]PETSC ERROR: MatICCFactorSymbolic() line 4611 in
> src/mat/interface/matrix.c
> [0]PETSC ERROR: PCSetup_ICC() line 117 in src/ksp/pc/impls/factor/icc/icc.c
> [0]PETSC ERROR: PCSetUp() line 801 in src/ksp/pc/interface/precon.c
> [0]PETSC ERROR: KSPSetUp() line 234 in src/ksp/ksp/interface/itfunc.c
> [0]PETSC ERROR: KSPSolve() line 338 in src/ksp/ksp/interface/itfunc.c
> =====================the solver convergence info======================
> Convergence in 0 iterations.
> writing solution to file temp_H.vtk ...
> number of unknowns >>435450
> finishing the numeric solver ...
> LSFIM hybrid method for four domain problem
> deallocating memory of domain class ...
> I debug the code, and the error is dumped by the funciton KSPSetUp()
> which should not take so much memory, but still 3108507040 memory was
> requested .... I really could not figure out where I need them...
> Any help will be appreciated.
> Thank you all
> Best regards
> Zhifeng
experiments is infinitely more interesting than any results to which
their experiments lead.
-- Norbert Wiener
