Dynamic allocation of Non zeros?
Zhifeng Sheng z.sheng at ewi.tudelft.nl
Fri Nov 2 07:23:40 CDT 2007
Barry Smith wrote:
> Zhifeng,
> We already do this; it helps with the time, but still results in very
> inefficient runs if your preallocation is zero entries.
> Perhaps you could describe how your matrix entries are generated and
> we can suggest a
> preallocation scheme?
> Barry
> On Nov 1, 2007, at 7:52 AM, Zhifeng Sheng wrote:
>> Dear all
>> It is always not easy to determine the number of nonzeros in a row
>> without any cost.
>> I wonder if I can make dynamic allocation, for instance, if one found
>> the nonzeros of a row overflow the pre-allocated space, then the
>> space shall be doubled.
>> This may waste some memory but it may not be that bad. Or maybe this
>> is already done in Petsc?
>> Could please tell what happens if I assign the nozero number in rows
>> to be zeros and let the programme fills in the nonzeros ?
>> Best regards
>> Zhifeng Sheng
In that case I'd better do some preallocation. I am working on 3D FEM
code with unstructured tetrahedron mesh, and on each node, we can have 3
to arround 12 unknowns, at this moment I assigned 50 nonzeros to each
rows, and it is sufficient... just half of the memory assigned went
wasted. Then I tried 25 nonzeros in a row, but this is not enough and
the performance is terrible.
So... do I really need to compute the nonzero pattern?
Ps. my matrix is SeqSBAIJ with block size 1, so I am wondering when I
specify the nonzeros in a row, does it mean the actually nonzeros
numbers or the memory that is needed? (for instance, for SeqSBAIJ, the
actual nonzeros in a row would twice as much as memory needed)
Thank you
Best regards
Zhifeng
