Help! Installing PETSc?
Bin xubinbin2004 at gmail.com
Wed Mar 14 00:56:21 CDT 2007
Hello,
I am trying to install PETSc on one of the workstations in my university. I
use the following commands for configuration:
 config/configure.py \
> --with-cc=mpicc \
> --with-fc=mpif90 \
> --with-mpi-dir=/opt/hpmpi/lib/linux_amd64/ \
> --with-mpi-shared=yes \
> LIBS=-lpgf90rtl \
> --with-debugging=yes \
> --with-superlu=yes \
> --with-superlu-dir=/usr/apps/src/superlu/SuperLU_3.0 \
> --download-superlu=no \
> --with-superlu_dist=yes \
> --with-superlu_dist-dir=/usr/apps/src/superlu/SuperLU_DIST_2.0 \
> --download-superlu_dist=no \
> --with-batch
> After this I got a message saying that:
Since your compute nodes require use of a batch system or mpirun you must:
> 1) Submit ./conftest to 1 processor of your batch system or system you are
>   cross-compiling for; this will generate the file reconfigure
>  2) Run "python reconfigure" (to complete the configure process).
So I tyoed:
mpirun -np 1 conftest
and got the following error message:
> *mpid: MPI BUG: execvp failed: Cannot execute conftest: No such file or
> directory*
> *MPI Application rank 0 exited before MPI_Init() with status 1*
> I found that there is only conftest.o !
> Can anybody help me?
> Thanks a lot.
> Yours truly,
> Bin Xu
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20070313/b72ed6c8/attachment.htm>
