Copying shared lib files
Aron Ahmadia aja2111 at columbia.edu
Tue Mar 13 07:06:50 CDT 2007
Hi Ben,
This is a  bad idea.  Unless the systems are virtually identical (same
versions of gcc, same processor architecture, same kernel, same system
layout) just to name a few, you WILL have problems with the libraries
after they've been copied over, though less problems are likely to
spring up if you linked them statically.
As a former Redhat user, I can attest to similar computers having a
same-versioned RH distro and still generating incompatible libraries.
~A
On 3/13/07, Ben Tay <zonexo at gmail.com> wrote:
> Hi,
> I've compiled PETSc on my school's server and I wonder if I can simply copy
> the compiled shared library/include files to my home comp's linux. Both uses
> redhat.
> Is there anything else I have to take care?
> Thank you
