Problem with using --download-f-blas-lapack=1 in windows
Sat Mar 3 10:28:45 CST 2007
if you have installation problems - send us configure.log at petsc-maint at mcs.anl.gov
Satish
On Sat, 3 Mar 2007, Ben Tay wrote:
> Hi,
> I tried to compile PETSc with compaq visual fortran in cygwin. My command is
> $ ./config/configure.py --with-cc='win32fe cl' --with-fc='win32fe f90'
> --download-f-blas-lapack=1 --with-f90-interface=win32 --with-x=0
> --with-mpi-dir=/cygdrive/c/program\ files/MPICH/SDK
> I then got this error message:
>      Compiling FBLASLAPACK; this may take several minutes
> TESTING: checkLib from config.packages.BlasLapack
> (python/BuildSystem/config/pack
>         UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log for
> detail
> s):
> Could not use downloaded f-blas-lapack?
> Can someone enlighten me what is wrong? Btw, I found the win32 libraries of
> blas/lapack in the externalpackages/fblaslapack/win32 directory
> Thank you.
