PETSc compiler
Aron Ahmadia
aja2111 at columbia.edu
Thu Jul 19 09:52:04 CDT 2007
Sumit,
The compilers are specified at the command-line when you make your
configure call.
i.e. from $PETSC_DIR
./config/configure.py --with-cc=gcc
if you need more information, try
./config/configure.py --help
And to answer your question, the compiler to use is stored in a
configuration file specific to your installation (generated by
configure.py), not in the generic common files.
Cheers
~A
On 7/19/07, Sumit Vaidya <sumit_vaidya at persistent.co.in> wrote:
> Hi,
> Where is the option to change the compiler?
> I saw $PCC in the bmake/common/variables file. Now I want to change the
> compiler.
> Where should I specify it?
> Regards,
> Sumit
> DISCLAIMER ========== This e-mail may contain privileged and confidential
> information which is the property of Persistent Systems Pvt. Ltd. It is
> intended only for the use of the individual or entity to which it is
> addressed. If you are not the intended recipient, you are not authorized to
> read, retain, copy, print, distribute or use this message. If you have
> received this communication in error, please notify the sender and delete
> all copies of this message. Persistent Systems Pvt. Ltd. does not accept any
> liability for virus infected mails.
