PETSc compiler
Thu Jul 19 09:42:11 CDT 2007
On 7/19/07, Sumit Vaidya <sumit_vaidya at persistent.co.in> wrote:
> Hi,
> Where is the option to change the compiler?
There is documentation on the installation page:
  http://www-unix.mcs.anl.gov/petsc/petsc-as/documentation/installation.html
and there is also documentation of all the options to configure:
  ./config/configure --help
The option you want is --with-cc.
    Matt
> I saw $PCC in the bmake/common/variables file. Now I want to change the
> compiler.
> Where should I specify it?
> Regards,
> Sumit
> DISCLAIMER ========== This e-mail may contain privileged and confidential
> information which is the property of Persistent Systems Pvt. Ltd. It is
> intended only for the use of the individual or entity to which it is
> addressed. If you are not the intended recipient, you are not authorized to
> read, retain, copy, print, distribute or use this message. If you have
> received this communication in error, please notify the sender and delete
> all copies of this message. Persistent Systems Pvt. Ltd. does not accept any
> liability for virus infected mails.
experiments is infinitely more interesting than any results to which
their experiments lead.
-- Norbert Wiener
