Difference between debugging and optimized version of PETSc
Mon Jan 29 21:12:54 CST 2007
  PETSc also does extensive additional "assert type" testing of input arguments
to functions etc in the debug version.
   Barry
On Mon, 29 Jan 2007, Matthew Knepley wrote:
> On 1/29/07, Ben Tay <zonexo at gmail.com> wrote:
> > Hi,
> > May I know what's the difference between the optimized and debugging
> > version?
> > Have the optimization flags such as -O3 been used in the compilcation of
> > the libraries for the optimized one? Whereas for the debugging version,
> > there is no optimization by the compiler?
> It is just the difference in compiler flags. You would have to look at the
> compiler documentation.
> If my program works fine in the debugging version, does it mean that I will
> > not get errors in the optimized version?
> Most likely.
>   Matt
> Thanks
