PETSc
Aron Ahmadia
aja2111 at columbia.edu
Sat Jan 27 18:09:49 CST 2007
Sounds like a documentation bug to me, are you referring to this?
http://www-unix.mcs.anl.gov/petsc/petsc-2/snapshots/petsc-current/docs/manualpages/DA/DARestoreGlobalVector.html#DARestoreGlobalVector
Perhaps I'm misunderstanding how Get/Restore are being used. I'll let
one of the developers chime in on this when they've got a moment.
~A
On 1/27/07, Brian Grierson <bag2107 at columbia.edu> wrote:
> Another quick question. PETSc online help says DAGetGlobal/DARestoreGlobal
> is a Seq vector operation, while
> DACreateGlobal/VecDesroy is parallel.
> I don't understand how you could create a global vector in a Seq manner on a
> DA???
> Brian A. Grierson
> Department of Applied Physics
> Columbia University
> Mobile: 646.259.1038
> Work: 212-854-4839
> bgrierson21 at gmail.com
> http://www.columbia.edu/~bag2107/http://www.apam.columbia.edu/ctx/ctx.html
> On Jan 27, 2007, at 6:41 PM, Aron Ahmadia wrote:
> Hi Brian,
> I took a quick peek at the source for DAGetGlobalVector in the current
> release:
> for (i=0; i<DA_MAX_WORK_VECTORS; i++) {
> if (da->globalin[i]) {
> *g = da->globalin[i];
> da->globalin[i] = PETSC_NULL;
> goto alldone;
> ierr = DACreateGlobalVector(da,g);CHKERRQ(ierr);
> alldone:
> if (!da->globalout[i]) {
> da->globalout[i] = *g;
> break;
> The two appear to be very similar, with this exception. Get/Restore
> work with one copy of the DA's global vector, but will make a copy if
> one has already been checked out or none exist.
> DACreateGlobalVector will always make a copy of the global vector,
> regardless of the circumstances. I think you're better off using Get
> and Restore (less data copying) unless you'd like to work with
> multiple copies for some reason.
> ~A
> Could you please tell me the difference between
> DACreateGlobalVector / VecDestroy
> and
> DAGetGlobalVector / DARestoreGlobalVector
> Brian A. Grierson
> Columbia University
> Work: 212-854-4839
