Lapack/blas and Gotoblas
Fri Jan 26 21:27:17 CST 2007
This mail belongs on petsc-maint.
On 1/26/07, Ben Tay <zonexo at gmail.com> wrote:
> Hi,
> My school's server has lapack and blas installed. However, I can't get it
> to be automatically detected by using ./configure. what is the filename that
> I should used? Is it liblapack.a and libblas.a? I can't find libblas.a in
> the /usr/lib directory though. Is there another filename for it? I found
> that if I specify just the dir (/usr/lib) or liblapack.a for both the
> lapack and blas lib, it won't work
It looks like you do not have BLAS installed.
Btw, can I use GotoBlas? I tried to specify libgoto.a or libgoto_northwoodp-
> r1.10.so and I managed to compile. However, during testing, the error msg
> are
> for libgoto.a :
> /nas/lsftmp/g0306332/petsc-2.3.2-p8/lib/linux-nompi-goto/libpetscksp.so:
> undefined reference to `pthread_create'
> undefined reference to `dpotrs_'
> undefined reference to `pthread_join'
This library depends on pthreads (at least), so you have to  specify it as
well:
  --with-blas-lib=[libgoto.a,libpthread.a]
for libgoto_northwoodp-r1.10.so :
This is not a full BLAS.
That was linked for shared library. If it is for static library, the error
> is:
> /nas/lsftmp/g0306332/petsc-2.3.2-p8/lib/linux-nompi-goto/libpetscksp.a(
> bcgsl.o)(.text+0x103a): In function `KSPSolve_BCGSL':
> : undefined reference to `dpotrs_'
> bcgsl.o)(.text+0x10f3): In function `KSPSolve_BCGSL':
> bcgsl.o)(.text+0x116f): In function `KSPSolve_BCGSL':
> /lsftmp/g0306332/GotoBLAS/libgoto.a(blas_server.o)(.text+0x370): In
> function `blas_thread_init':
> : undefined reference to `pthread_create'
> /lsftmp/g0306332/GotoBLAS/libgoto.a(blas_server.o)(.text+0x709): In
> function `blas_thread_shutdown_':
> So can gotoblas be used?
> Thank you very much
One trouble is that despite this system, anyone who reads journals widely
and critically is forced to realize that there are scarcely any bars to
eventual
publication. There seems to be no study too fragmented, no hypothesis too
trivial, no literature citation too biased or too egotistical, no design too
warped, no methodology too bungled, no presentation of results too
inaccurate, too obscure, and too contradictory, no analysis too
self-serving,
no argument too circular, no conclusions too trifling or too unjustified,
and
no grammar and syntax too offensive for a paper to end up in print. --
Drummond Rennie
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20070126/2ed68803/attachment.htm>
