graphic dump on cluster
    Aron Ahmadia
    aja2111 at columbia.edu
    Wed Jan 24 17:03:17 CST 2007
Hi Jianing,
I don't think the orion cluster is set up for the worker nodes to be able to
connect back to a remote workstation.  I would collect the data locally on
the master node, and use PETSC_VIEWER_DRAW_SELF.
Please double-check that the display code works on single-processor jobs,
that error looks like an X11 setup error as Matt notes.
~A
On 1/24/07, js2615 at columbia.edu <js2615 at columbia.edu> wrote:
> Hi Petsc experts,
> I have a question about the graphic output using multiple
> processors.  Suppose I am using X11 to ssh into the cluster, and
> would like to view the graphical output at each iteration using
> ierr = VecView(x,PETSC_VIEWER_DRAW_WORLD);CHKERRQ(ierr);
> I got the following error message, turns out, when I use multiple
> processors (not a problem using one processor though):
> Unable to open display on localhost:10.0
> .  Make sure your COMPUTE NODES are authorized to connect
>     to this X server and either your DISPLAY variable
>     is set or you use the -display name option
> [3]PETSC ERROR: [1]PETSC ERROR: Libraries linked from
> /opt/petsc-2.3.2/lib/linux-gnu-c-debug
> [2]PETSC ERROR:
> [3]PETSC ERROR: Configure run at Fri Oct 27 11:40:04 2006
> Petsc Release Version 2.3.2, Patch 3, Fri Sep 29 17:09:34 CDT 2006
> HG revision: 9215af156a9cbcdc1ec666e2b5c7934688ddc526
> [3]PETSC ERROR: Libraries linked from
> See docs/changes/index.html for recent updates.
> [2]PETSC ERROR: [3]PETSC ERROR: See docs/faq.html for hints about
> trouble shooting.
> [3]PETSC ERROR: See docs/index.html for manual pages.
> [1]PETSC ERROR: [3]PETSC ERROR:
> Configure options --with-mpich=/opt/mpich2
> --with-blas-lapack=lib=/usr/lib/libatlas.so --with-shared=0
> [3]PETSC ERROR: ./ex19 on a linux-gnu named n0010 by jianing Wed Jan
> 24 16:36:03 2007
> [2]PETSC ERROR:
> [2]PETSC ERROR: PetscDrawXGetDisplaySize_Private() line 618 in
> src/sys/draw/impls/x/xops.c
> [2]PETSC ERROR: [3]PETSC ERROR: PETSc unable to use X windows
> proceeding without graphics
> [1]PETSC ERROR: Configure options --with-mpich=/opt/mpich2
> [3]PETSC ERROR: [1]PETSC ERROR: Configure options
> [3]PETSC ERROR: PetscDrawXGetDisplaySize_Private() line 618 in
> [1]PETSC ERROR: PETSc unable to use X windows
> Is there any permission issue I need to set up?
> Thanks,
> Jianing
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20070124/c0763f9f/attachment.htm>
