mpi not working
Ben Tay zonexo at gmail.com
Tue Jan 16 18:34:36 CST 2007
Thanks Shaman. But the problem is that I get
0,1
0,1
0,1
0,1
instead of
0,4
1,4
2,4
3,4 which means there are 4 processors instead of the above, whereby it
seems that 4 serial jobs are running.
Barry:
The script was given by my school when parallel jobs are to be submitted. I
use the same script when submitting pure mpi job and it works. On the other
hand, the PETSc parallel code ran successfully on another of my school's
server. It was also submitted using a script, but a slightly different one
since it's another system. However, that server is very busy hence I usually
use the current server.
Do you have other other solution? Or should I try other ways of compilation?
Btw, I am using ifc 7.0 and icc 7.0. The codes are written in fortran.
Thank you.
On 1/16/07, Barry Smith <bsmith at mcs.anl.gov> wrote:
> Ben,
>   You definitely have to submit a PETSc job just like
> any other MPI job. So please try using the script.
>   Barry
> On Tue, 16 Jan 2007, Ben Tay wrote:
> > Hi Pan,
> > I also got very big library files if I use PETSc with mpich2.
> > Btw, I have tried several options but I still don't understand why I
> can't
> > get mpi to work with PETSc.
> > The 4 processors are running together but each running its own code.
> > I just use
> > integer :: nprocs,rank,ierr
> > call PetscInitialize(PETSC_NULL_CHARACTER,ierr)
> > call MPI_Comm_rank(PETSC_COMM_WORLD,rank,ierr)
> > call MPI_Comm_size(PETSC_COMM_WORLD,nprocs,ierr)
> > print *, rank, nprocs
> > call PetscFinalize(ierr)
> > The answers I get is 0,1 repeated 4 times instead of 0,4 1,4 2,4 3,4.
> > I'm using my school's server's mpich and it work if I just compile in
> pure
> > mpi.
> > Btw, if I need to send the job to 4 processors, I need to use a script
> file:
> > #BSUB -o std-output
> > #BSUB -q linux_parallel_test
> > #BSUB -n 4
> > /usr/lsf6/bin/mpijob_gm /opt/mpich/myrinet/intel/bin/mpirun a.out
> > I wonder if the problem lies here...
> > Thank you.
> > On 1/16/07, li pan <li76pan at yahoo.com> wrote:
> > > I did try to download and install petsc2.3.2, but end
> > > up with error: mpich can not be download & installed,
> > > please install mpich for windows manually.
> > > In the homepage of mpich2, I didn't choose the version
> > > for windows but the source code version. And compiled
> > > it by myself. Then, I gave the --with-mpi-dir="install
> > > dir". Petsc was configured, and now it's doing "make".
> > > One interesting thing is, I installed petsc in linux
> > > before. The mpi libraries were very large
> > > (libmpich.a==60 mb). But this time in cygwin it was
> > > only several mbs.
> > > best
> > > pan
> > > --- Ben Tay <zonexo at gmail.com> wrote:
> > > > hi,
> > > > i install PETSc using the following command:
> > > > ./config/configure.py --with-vendor-compilers=intel
> > > > --with-gnu-compilers=0
> > > --with-blas-lapack-dir=/lsftmp/g0306332/inter/mkl/lib/32
> > > > --with-mpi-dir=/opt/mpich/intel/ --with-x=0
> > > > --with-shared
> > > > then i got:
> > > > Compilers:
> > > >   C Compiler:         /opt/mpich/intel/bin/mpicc
> > > > -fPIC -g
> > > >   Fortran Compiler:   /opt/mpich/intel/bin/mpif90
> > > > -I. -fPIC -g -w90 -w
> > > > Linkers:
> > > >   Shared linker:   /opt/mpich/intel/bin/mpicc
> > > > -shared  -fPIC -g
> > > >   Dynamic linker:   /opt/mpich/intel/bin/mpicc
> > > > -shared  -fPIC -g
> > > > PETSc:
> > > >   PETSC_ARCH: linux-mpif90
> > > >   PETSC_DIR: /nas/lsftmp/g0306332/petsc-2.3.2-p8
> > > >   ** Now build and test the libraries with "make all
> > > > test"
> > > >   Clanguage: C
> > > >   Scalar type:real
> > > > MPI:
> > > >   Includes: ['/opt/mpich/intel/include']
> > > >   PETSc shared libraries: enabled
> > > >   PETSc dynamic libraries: disabled
> > > > BLAS/LAPACK:
> > > > -Wl,-rpath,/lsftmp/g0306332/inter/mkl/lib/32
> > > > -L/lsftmp/g0306332/inter/mkl/lib/32 -lmkl_lapack
> > > > -lmkl_ia32 -lguide
> > > > i ran "make all test" and everything seems fine
> > > > /opt/mpich/intel/bin/mpicc -c -fPIC -g
> > > -I/nas/lsftmp/g0306332/petsc-2.3.2-p8-I/nas/lsftmp/g0306332/petsc-
> > > > 2.3.2-p8/bmake/linux-mpif90
> > > > -I/nas/lsftmp/g0306332/petsc-2.3.2-p8/include
> > > > -I/opt/mpich/intel/include
> > > > -D__SDIR__="src/snes/examples/tutorials/" ex19.c
> > > > /opt/mpich/intel/bin/mpicc -fPIC -g  -o ex19
> > > > ex19.o-Wl,-rpath,/nas/lsftmp/g0306332/petsc-
> > > > 2.3.2-p8/lib/linux-mpif90
> > > -L/nas/lsftmp/g0306332/petsc-2.3.2-p8/lib/linux-mpif90
> > > > -lpetscsnes -lpetscksp -lpetscdm -lpetscmat
> > > > -lpetscvec -lpetsc
> > > > -lmkl_ia32 -lguide
> > > > -lPEPCF90 -Wl,-rpath,/opt/intel/compiler70/ia32/lib
> > > > -Wl,-rpath,/opt/mpich/intel/lib
> > > > -L/opt/mpich/intel/lib -Wl,-rpath,-rpath
> > > > -Wl,-rpath,-ldl -L-ldl -lmpich
> > > > -L/opt/intel/compiler70/ia32/lib
> > > > -Wl,-rpath,/usr/lib -Wl,-rpath,/usr/lib -L/usr/lib
> > > > -limf -lirc -lcprts -lcxa
> > > > -lunwind -ldl -lmpichf90 -lPEPCF90
> > > > -L/opt/intel/compiler70/ia32/lib -Wl,-rpath,/usr/lib
> > > > -L/usr/lib -lintrins
> > > > -lIEPCF90 -lF90 -lm  -Wl,-rpath,\ -Wl,-rpath,\ -L\
> > > > -ldl -lmpich
> > > > -Wl,-rpath,/usr/lib -L/usr/lib -limf -lirc -lcprts
> > > > -lcxa -lunwind -ldl
> > > > /bin/rm -f ex19.o
> > > > C/C++ example src/snes/examples/tutorials/ex19 run
> > > > successfully with 1 MPI
> > > > process
> > > > successfully with 2 MPI
> > > > processes
> > > > Fortran example src/snes/examples/tutorials/ex5f run
> > > > process
> > > > Completed test examples
> > > > I then tried to run my own parallel code. It's a
> > > > simple code which prints
> > > > the rank of each processor.
> > > > If I compile the code using just mpif90 test.F(using
> > > > just mpif.h)
> > > > I get 0,1,2,3 (4 processors).
> > > > however, if i change the code to use petsc.h etc
> > > > ie.
> > > >         program ns2d_c
> > > >         implicit none
> > > > #include "include/finclude/petsc.h"
> > > > #include "include/finclude/petscvec.h"
> > > > #include "include/finclude/petscmat.h"
> > > > #include "include/finclude/petscksp.h"
> > > > #include "include/finclude/petscpc.h"
> > > > #include "include/finclude/petscmat.h90"
> > > >         integer,parameter :: size_x=8,size_y=4
> > > >         integer ::
> > > > ierr,Istart_p,Iend_p,Ntot,Istart_m,Iend_m,k
> > > >  PetscMPIInt     nprocs,rank
> > > >         call
> > > >         call
> > > > end program ns2d_c
> > > > i then rename the filename to ex2f.F and use "make
> > > > ex2f"
> > > > the result I get is something like 0,0,0,0.
> > > > Why is this so?
> > > > Thank you.
> ____________________________________________________________________________________
> > > Never Miss an Email
> > > Stay connected with Yahoo! Mail on your mobile.  Get started!
> > > http://mobile.yahoo.com/services?promote=mail
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20070117/44c1a04f/attachment.htm>
