mpi not working
    Barry Smith
    bsmith at mcs.anl.gov
    Tue Jan 16 07:32:18 CST 2007
  Ben,
   You definitely have to submit a PETSc job just like
any other MPI job. So please try using the script.
   Barry
On Tue, 16 Jan 2007, Ben Tay wrote:
> Hi Pan,
> I also got very big library files if I use PETSc with mpich2.
> Btw, I have tried several options but I still don't understand why I can't
> get mpi to work with PETSc.
> The 4 processors are running together but each running its own code.
> I just use
> integer :: nprocs,rank,ierr
> call PetscInitialize(PETSC_NULL_CHARACTER,ierr)
> call MPI_Comm_rank(PETSC_COMM_WORLD,rank,ierr)
> call MPI_Comm_size(PETSC_COMM_WORLD,nprocs,ierr)
> print *, rank, nprocs
> call PetscFinalize(ierr)
> The answers I get is 0,1 repeated 4 times instead of 0,4 1,4 2,4 3,4.
> I'm using my school's server's mpich and it work if I just compile in pure
> mpi.
> Btw, if I need to send the job to 4 processors, I need to use a script file:
> #BSUB -o std-output
> #BSUB -q linux_parallel_test
> #BSUB -n 4
> /usr/lsf6/bin/mpijob_gm /opt/mpich/myrinet/intel/bin/mpirun a.out
> I wonder if the problem lies here...
> Thank you.
> On 1/16/07, li pan <li76pan at yahoo.com> wrote:
> > I did try to download and install petsc2.3.2, but end
> > up with error: mpich can not be download & installed,
> > please install mpich for windows manually.
> > In the homepage of mpich2, I didn't choose the version
> > for windows but the source code version. And compiled
> > it by myself. Then, I gave the --with-mpi-dir="install
> > dir". Petsc was configured, and now it's doing "make".
> > One interesting thing is, I installed petsc in linux
> > before. The mpi libraries were very large
> > (libmpich.a==60 mb). But this time in cygwin it was
> > only several mbs.
> > best
> > pan
> > --- Ben Tay <zonexo at gmail.com> wrote:
> > > hi,
> > > i install PETSc using the following command:
> > > ./config/configure.py --with-vendor-compilers=intel
> > > --with-gnu-compilers=0
> > --with-blas-lapack-dir=/lsftmp/g0306332/inter/mkl/lib/32
> > > --with-mpi-dir=/opt/mpich/intel/ --with-x=0
> > > --with-shared
> > > then i got:
> > > Compilers:
> > >   C Compiler:         /opt/mpich/intel/bin/mpicc
> > > -fPIC -g
> > >   Fortran Compiler:   /opt/mpich/intel/bin/mpif90
> > > -I. -fPIC -g -w90 -w
> > > Linkers:
> > >   Shared linker:   /opt/mpich/intel/bin/mpicc
> > > -shared  -fPIC -g
> > >   Dynamic linker:   /opt/mpich/intel/bin/mpicc
> > > -shared  -fPIC -g
> > > PETSc:
> > >   PETSC_ARCH: linux-mpif90
> > >   PETSC_DIR: /nas/lsftmp/g0306332/petsc-2.3.2-p8
> > >   ** Now build and test the libraries with "make all
> > > test"
> > >   Clanguage: C
> > >   Scalar type:real
> > > MPI:
> > >   Includes: ['/opt/mpich/intel/include']
> > >   PETSc shared libraries: enabled
> > >   PETSc dynamic libraries: disabled
> > > BLAS/LAPACK:
> > > -Wl,-rpath,/lsftmp/g0306332/inter/mkl/lib/32
> > > -L/lsftmp/g0306332/inter/mkl/lib/32 -lmkl_lapack
> > > -lmkl_ia32 -lguide
> > > i ran "make all test" and everything seems fine
> > > /opt/mpich/intel/bin/mpicc -c -fPIC -g
> > -I/nas/lsftmp/g0306332/petsc-2.3.2-p8-I/nas/lsftmp/g0306332/petsc-
> > > 2.3.2-p8/bmake/linux-mpif90
> > > -I/nas/lsftmp/g0306332/petsc-2.3.2-p8/include
> > > -I/opt/mpich/intel/include
> > > -D__SDIR__="src/snes/examples/tutorials/" ex19.c
> > > /opt/mpich/intel/bin/mpicc -fPIC -g  -o ex19
> > > ex19.o-Wl,-rpath,/nas/lsftmp/g0306332/petsc-
> > > 2.3.2-p8/lib/linux-mpif90
> > -L/nas/lsftmp/g0306332/petsc-2.3.2-p8/lib/linux-mpif90
> > > -lpetscsnes -lpetscksp -lpetscdm -lpetscmat
> > > -lpetscvec -lpetsc
> > > -lmkl_ia32 -lguide
> > > -lPEPCF90 -Wl,-rpath,/opt/intel/compiler70/ia32/lib
> > > -Wl,-rpath,/opt/mpich/intel/lib
> > > -L/opt/mpich/intel/lib -Wl,-rpath,-rpath
> > > -Wl,-rpath,-ldl -L-ldl -lmpich
> > > -L/opt/intel/compiler70/ia32/lib
> > > -Wl,-rpath,/usr/lib -Wl,-rpath,/usr/lib -L/usr/lib
> > > -limf -lirc -lcprts -lcxa
> > > -lunwind -ldl -lmpichf90 -lPEPCF90
> > > -L/opt/intel/compiler70/ia32/lib -Wl,-rpath,/usr/lib
> > > -L/usr/lib -lintrins
> > > -lIEPCF90 -lF90 -lm  -Wl,-rpath,\ -Wl,-rpath,\ -L\
> > > -ldl -lmpich
> > > -Wl,-rpath,/usr/lib -L/usr/lib -limf -lirc -lcprts
> > > -lcxa -lunwind -ldl
> > > /bin/rm -f ex19.o
> > > C/C++ example src/snes/examples/tutorials/ex19 run
> > > successfully with 1 MPI
> > > process
> > > successfully with 2 MPI
> > > processes
> > > Fortran example src/snes/examples/tutorials/ex5f run
> > > process
> > > Completed test examples
> > > I then tried to run my own parallel code. It's a
> > > simple code which prints
> > > the rank of each processor.
> > > If I compile the code using just mpif90 test.F(using
> > > just mpif.h)
> > > I get 0,1,2,3 (4 processors).
> > > however, if i change the code to use petsc.h etc
> > > ie.
> > >         program ns2d_c
> > >         implicit none
> > > #include "include/finclude/petsc.h"
> > > #include "include/finclude/petscvec.h"
> > > #include "include/finclude/petscmat.h"
> > > #include "include/finclude/petscksp.h"
> > > #include "include/finclude/petscpc.h"
> > > #include "include/finclude/petscmat.h90"
> > >         integer,parameter :: size_x=8,size_y=4
> > >         integer ::
> > > ierr,Istart_p,Iend_p,Ntot,Istart_m,Iend_m,k
> > >  PetscMPIInt     nprocs,rank
> > >         call
> > >         call
> > > end program ns2d_c
> > > i then rename the filename to ex2f.F and use "make
> > > ex2f"
> > > the result I get is something like 0,0,0,0.
> > > Why is this so?
> > > Thank you.
> > ____________________________________________________________________________________
> > Never Miss an Email
> > Stay connected with Yahoo! Mail on your mobile.  Get started!
> > http://mobile.yahoo.com/services?promote=mail
