Can I use ATLAS for the blas/lapack library
Thierry Thomas
thierry at pompo.net
Sat Jan 13 01:18:32 CST 2007
Le Sam 13 jan 07 à 2:45:29 +0100, Ben Tay <zonexo at gmail.com>
écrivait :
> Hi,
Hello,
> I've ATLAS on my server. Can I use it for the blas/lapack library?
> I tried to specify the directory and also the the library files but the
> PETSc configuration keep saying it's not valid.
Yes, you can! Here is an extract of the FreeBSD port's Makefile:
.if defined(WITH_ATLAS)
LIB_DEPENDS+= atlas.2:${PORTSDIR}/math/atlas
LIBBLASLAPACK= "-L${LOCALBASE}/lib -lalapack -lf77blas -latlas -lm"
.else
LIB_DEPENDS+= lapack.4:${PORTSDIR}/math/lapack
LIBBLASLAPACK= "-L${LOCALBASE}/lib -llapack -lblas -lm"
.endif
CONFIGURE_ARGS+= --with-blas-lapack-lib=${LIBBLASLAPACK}
Th. Thomas.
