Matthew Knepley
    knepley at gmail.com
    Fri Jan 12 15:51:45 CST 2007
Why are you creating that ISGeneral with PETSC_COMM_WORLD. It does not
seem to be global? Shouldn't it be PETSC_COMM_SELF? Also, what are you
trying to do?
  Matt
On 1/12/07, Arvid Bessen <bessen at cs.columbia.edu> wrote:
> Dear all,
> I have a problem with MPI in PETSc that is probably simple and you
> will hopefully know the answer to. In my code I treat the local rows
> of a MPIAIJ matrix one by one. If the number of local rows is equal
> on all processors, everything works well. However, if the number of
> rows is different, the program crashes. I have attached a simple
> example program to demonstrate what I want to do.
> Suppose process A has one more local row than process B. In the
> debugger I found out that the crash occurs in "MPI_Allreduce".
> Process A will call MPI_Allreduce one more time than process B,
> because it processes an additional row. While process A is still
> waiting for the result of the last MPI_Allreduce, process B will
> proceed and call MPI_Allreduce in a different context. This is, when
> What is the best way to make sure that all MPI calls are matched on
> the different processes?
> Thanks,
> Arvid
> static char help[] = "Example program with different row sizes\n\n";
> #include "petscmat.h"
> #undef __FUNCT__
> #define __FUNCT__ "main"
> int main(int Argc,char **Args)
>    const PetscInt  size = 3;
>    PetscErrorCode  ierr;
>    Mat             cmat, dmat;
>    PetscInt        cmat_loc_start, cmat_loc_end, cmat_loc_size;
>    PetscInt        *rowsize_arr = 0;
>    const PetscInt  **row_arr = 0;
>    IS              *is_arr = 0;
>    PetscInt        a;
>    Mat            *submat_arr = 0;
>    PetscInitialize(&Argc,&Args,(char *)0,help);
>    ierr = MatCreateMPIAIJ(PETSC_COMM_WORLD, PETSC_DECIDE,
> PETSC_DECIDE, size, size,
>                          1, PETSC_NULL, 2, PETSC_NULL, &cmat);CHKERRQ(ierr);
>    ierr = MatAssemblyBegin(cmat,MAT_FINAL_ASSEMBLY);CHKERRQ(ierr);
>    ierr = MatAssemblyEnd(cmat,MAT_FINAL_ASSEMBLY);CHKERRQ(ierr);
>                          1, PETSC_NULL, 2, PETSC_NULL, &dmat);CHKERRQ(ierr);
>    ierr = MatAssemblyBegin(dmat,MAT_FINAL_ASSEMBLY);CHKERRQ(ierr);
>    ierr = MatAssemblyEnd(dmat,MAT_FINAL_ASSEMBLY);CHKERRQ(ierr);
>    ierr = MatGetOwnershipRange(cmat, &cmat_loc_start, &cmat_loc_end);
> CHKERRQ(ierr);
>    cmat_loc_size = cmat_loc_end-cmat_loc_start;
>    ierr = PetscMalloc(sizeof(PetscInt *)*cmat_loc_size, &row_arr);
> CHKERRQ(ierr);
>    ierr = PetscMalloc(sizeof(PetscInt)*cmat_loc_size, &rowsize_arr);
> CHKERRQ(ierr);
>    ierr = PetscMalloc(sizeof(IS)*cmat_loc_size, &is_arr); CHKERRQ(ierr);
>    for( a=0; a<cmat_loc_size; a++ ) {
>      ierr = MatGetRow(cmat, a+cmat_loc_start, &(rowsize_arr[a]), &
> (row_arr[a]), 0); CHKERRQ(ierr);
>      ierr = ISCreateGeneral(PETSC_COMM_WORLD, rowsize_arr[a], row_arr
> [a], &(is_arr[a])); CHKERRQ(ierr);
>      ierr = MatRestoreRow(cmat, a+cmat_loc_start, &(rowsize_arr[a]), &
>    ierr = PetscMalloc(sizeof(Mat)*cmat_loc_size, &submat_arr); CHKERRQ
> (ierr);
>    ierr = MatGetSubMatrices(dmat, cmat_loc_size, is_arr, is_arr,
> MAT_INITIAL_MATRIX, &submat_arr); CHKERRQ(ierr);
>    ierr = PetscFinalize();CHKERRQ(ierr);
>    return 0;
One trouble is that despite this system, anyone who reads journals widely
and critically is forced to realize that there are scarcely any bars to eventual
publication. There seems to be no study too fragmented, no hypothesis too
trivial, no literature citation too biased or too egotistical, no design too
warped, no methodology too bungled, no presentation of results too
inaccurate, too obscure, and too contradictory, no analysis too self-serving,
no argument too circular, no conclusions too trifling or too unjustified, and
no grammar and syntax too offensive for a paper to end up in print. --
Drummond Rennie
