No subject
Arvid Bessen bessen at cs.columbia.edu
Fri Jan 12 15:41:49 CST 2007
Dear all,
I have a problem with MPI in PETSc that is probably simple and you
will hopefully know the answer to. In my code I treat the local rows
of a MPIAIJ matrix one by one. If the number of local rows is equal
on all processors, everything works well. However, if the number of
rows is different, the program crashes. I have attached a simple
example program to demonstrate what I want to do.
Suppose process A has one more local row than process B. In the
debugger I found out that the crash occurs in "MPI_Allreduce".
Process A will call MPI_Allreduce one more time than process B,
because it processes an additional row. While process A is still
waiting for the result of the last MPI_Allreduce, process B will
proceed and call MPI_Allreduce in a different context. This is, when
What is the best way to make sure that all MPI calls are matched on
the different processes?
Arvid
static char help[] = "Example program with different row sizes\n\n";
#include "petscmat.h"
#undef __FUNCT__
#define __FUNCT__ "main"
int main(int Argc,char **Args)
   const PetscInt  size = 3;
   PetscErrorCode  ierr;
   Mat             cmat, dmat;
   PetscInt        cmat_loc_start, cmat_loc_end, cmat_loc_size;
   PetscInt        *rowsize_arr = 0;
   const PetscInt  **row_arr = 0;
   IS              *is_arr = 0;
   PetscInt        a;
   Mat            *submat_arr = 0;
   PetscInitialize(&Argc,&Args,(char *)0,help);
   ierr = MatCreateMPIAIJ(PETSC_COMM_WORLD, PETSC_DECIDE,
PETSC_DECIDE, size, size,
			 1, PETSC_NULL, 2, PETSC_NULL, &cmat);CHKERRQ(ierr);
   ierr = MatAssemblyBegin(cmat,MAT_FINAL_ASSEMBLY);CHKERRQ(ierr);
   ierr = MatAssemblyEnd(cmat,MAT_FINAL_ASSEMBLY);CHKERRQ(ierr);
			 1, PETSC_NULL, 2, PETSC_NULL, &dmat);CHKERRQ(ierr);
   ierr = MatAssemblyBegin(dmat,MAT_FINAL_ASSEMBLY);CHKERRQ(ierr);
   ierr = MatAssemblyEnd(dmat,MAT_FINAL_ASSEMBLY);CHKERRQ(ierr);
   ierr = MatGetOwnershipRange(cmat, &cmat_loc_start, &cmat_loc_end);
CHKERRQ(ierr);
   cmat_loc_size = cmat_loc_end-cmat_loc_start;
   ierr = PetscMalloc(sizeof(PetscInt *)*cmat_loc_size, &row_arr);
CHKERRQ(ierr);
   ierr = PetscMalloc(sizeof(PetscInt)*cmat_loc_size, &rowsize_arr);
CHKERRQ(ierr);
   ierr = PetscMalloc(sizeof(IS)*cmat_loc_size, &is_arr); CHKERRQ(ierr);
   for( a=0; a<cmat_loc_size; a++ ) {
     ierr = MatGetRow(cmat, a+cmat_loc_start, &(rowsize_arr[a]), &
(row_arr[a]), 0); CHKERRQ(ierr);
     ierr = ISCreateGeneral(PETSC_COMM_WORLD, rowsize_arr[a], row_arr
[a], &(is_arr[a])); CHKERRQ(ierr);
     ierr = MatRestoreRow(cmat, a+cmat_loc_start, &(rowsize_arr[a]), &
   ierr = PetscMalloc(sizeof(Mat)*cmat_loc_size, &submat_arr); CHKERRQ
(ierr);
   ierr = MatGetSubMatrices(dmat, cmat_loc_size, is_arr, is_arr,
MAT_INITIAL_MATRIX, &submat_arr); CHKERRQ(ierr);
   ierr = PetscFinalize();CHKERRQ(ierr);
   return 0;
