PETSc and gfortran
Paul T. Bauman
pbauman at ices.utexas.edu
Wed Jan 10 17:37:44 CST 2007
Yes, example ex5f broke in the exact same way. Note the preceding c/c++
examples worked perfectly. How would you suggest I proceed? Thanks,
Paul
Satish Balay wrote:
> Can you reproduce this with a PETSc example?
> make test
> Satish
> On Wed, 10 Jan 2007, Paul T. Bauman wrote:
>> Hello,
>> Has anyone had any experience using PETSc and gfortran together? My code
>> compiles, but when I run it, it crashes with the following error (mac Tiger
>> 10.4.8, power pc, latest build of gfortran, MPICH2, petsc 2.3.2):
>> [0]PETSC ERROR:
>> [0]PETSC ERROR: Caught signal number 10 BUS: Bus Error, possibly illegal
>> memory access
>> [0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
>> [0]PETSC ERROR: or see
>> http://www.mcs.anl.gov/petsc/petsc-as/documentation/troubleshooting.html#Signal[0]PETSC
>> ERROR: or try http://valgrind.org on linux or man libgmalloc on Apple to find
>> memory corruption errors
>> [0]PETSC ERROR: likely location of problem given in stack below
>> [0]PETSC ERROR: --------------------- Stack Frames
>> [0]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
>> [0]PETSC ERROR: INSTEAD the line number of the start of the function
>> [0]PETSC ERROR: is given.
>> [0]PETSC ERROR: --------------------- Error Message
>> [0]PETSC ERROR: Signal received!
>> [0]PETSC ERROR:
>> [0]PETSC ERROR: Petsc Release Version 2.3.2, Patch 8, Tue Jan 2 14:33:59 PST
>> 2007 HG revision: ebeddcedcc065e32fc252af32cf1d01ed4fc7a80
>> [0]PETSC ERROR: See docs/changes/index.html for recent updates.
>> [0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
>> [0]PETSC ERROR: See docs/index.html for manual pages.
>> [0]PETSC ERROR:
>> [0]PETSC ERROR: EXEC/shrink_tao on a Apple_Pow named
>> dhcp-67-30.ices.utexas.edu by pbauman Wed Jan 10 17:20:03 2007
>> [0]PETSC ERROR: Libraries linked from
>> /Users/pbauman/LIBRARIES/PETSC/petsc-2.3.2-p8/lib/Apple_PowerPC_Tiger_Debug
>> [0]PETSC ERROR: Configure run at Tue Jan 9 15:42:42 2007
>> [0]PETSC ERROR: Configure options --with-shared=0 --with-clanguage=C++
>> --with-mpi-dir=/Users/pbauman/LIBRARIES/MPICH/mpich2-1.0.5_Apple_PowerPC_Tiger_gcc_gfortran
>> --with-blas-lapack-dir=/Users/pbauman/LIBRARIES/PETSC/petsc-2.3.2-p8/externalpackages/fblaslapack/Apple_PowerPC_Tiger_Debug/
>> [0]PETSC ERROR:
>> [0]PETSC ERROR: User provided function() line 0 in unknown directory unknown
>> file
>> [cli_0]: aborting job:
>> application called MPI_Abort(MPI_COMM_WORLD, 59) - process 0
>> rank 0 in job 2 dhcp-67-30.ices.utexas.edu_50482 caused collective abort of
>> all ranks
>> exit status of rank 0: return code 59
>> make: *** [run_shrink_tao_tr] Error 59
>> This happens at the very beginning of the code (I put a write statement in at
>> the first line of the program and nothing came out). This code runs
>> successfully on linux with intel compilers. I'm sure the problem is somehow
>> with gfortran/my build, I'm just not sure where to begin with this kind of
>> problem, so I thought I'd see if anyone had a similar experience.
>> Thanks,
>> Paul
