Error during example compilation of test examples
Ben Tay zonexo at gmail.com
Fri Aug 24 23:09:05 CDT 2007
I didn't touch the petscmat.h and I've verified that the 2 lines are
there. Could it be some compilation error of PETSc? I can send in the
configure.log if required.
thanks.
Satish Balay wrote:
> I can't reproduce this error. Can you verify that finclude/petscmat.h
> is unmodified?
> It should have the following 2 lines - so the variable is
> declared correctly.
>       PetscEnum MATOP_IS_STRUCTURALLY_SYMMETRIC        (Line:384)
>       parameter(MATOP_IS_STRUCTURALLY_SYMMETRIC=87)    (Line:492)
> Satish
> balay at parth ~/petsc-2.3.3-p4/src/ksp/ksp/examples/tutorials
> $ make ex1f
> /home/balay/petsc-2.3.3-p4/bin/win32fe/win32fe f90 -c  -threads -debug:full -fpp:-m  -I/home/balay/petsc-2.3.3-p4 -I/home/balay/petsc-2.3.3-p4/bmake/cygwin-ms -I/home/balay/petsc-2.3.3-p4/include -I/cygdrive/c/Program\ Files/MPICH/SDK/include        -o ex1f.o ex1f.F
> ex1f.i
> /home/balay/petsc-2.3.3-p4/bin/win32fe/win32fe f90 -threads -debug:full -fpp:-m  -o ex1f ex1f.o  -L/home/balay/petsc-2.3.3-p4/lib/cygwin-ms -L/home/balay/petsc-2.3.3-p4/lib/cygwin-ms -lpetscksp -lpetscdm -lpetscmat -lpetscvec -lpetsc    /cygdrive/c/Program\ Files/MPICH/SDK/lib/mpich.lib /cygdrive/c/Program\ Files/Intel/MKL/ia32/lib/mkl_s_dll.lib Gdi32.lib User32.lib Advapi32.lib Kernel32.lib Ws2_32.lib
> output_name: h:\home\balay\PETSC-~1.3-P\src\ksp\ksp\examples\TUTORI~1\ex1f.exe
> outfile:
> /usr/bin/rm -f ex1f.o
> $ ./ex1f
> KSP Object:
>   type: gmres
>     GMRES: restart=30, using Classical (unmodified) Gram-Schmidt Orthogonalization with no iterative refinement
>     GMRES: happy breakdown tolerance 1e-030
>   maximum iterations=10000, initial guess is zero
>   tolerances:  relative=1e-007, absolute=1e-050, divergence=10000
>   left preconditioning
> PC Object:
>   type: jacobi
>   linear system matrix = precond matrix:
>   Matrix Object:
>     type=seqaij, rows=10, cols=10
>     total: nonzeros=28, allocated nonzeros=50
>       not using I-node routines
> Norm of error < 1.e-12,Iterations =     5
> On Thu, 23 Aug 2007, Ben Tay wrote:
>> Hi,
>> I got this error while trying to compile the test example in
>> src/ksp/ksp/example/tutorials/ex1f
>> /codes/petsc-2.3.3-p4/bin/win32fe/win32fe f90 -c  -threads -debug:full -fpp:-m
>> -I/codes/petsc-2.3.3-p4 -I/codes/petsc-2.3.3-p4/bmake/win32
>> -p4/include -I/codes/petsc-2.3.3-p4/include/mpiuni        -o ex1f.o ex1f.F
>> ex1f.i
>> d:\cygwin\CODES\PETSC-~2.3-P\include/finclude/petscmat.h(492) : Error: This
>> name
>> does not have a type, and must have an explicit type.
>> [MATOP_IS_STRUCTURALLY_
>> SYMMETRIC]
>> make: [ex1f.o] Error 1 (ignored)
>> Also here on ex5f:
>> --------------Error detected during compile or link!-----------------------
>> See http://www.mcs.anl.gov/petsc/petsc-2/documentation/troubleshooting.html
>> /finclude -threads -debug:full -fpp:-m  -I/codes/petsc-2.3.3-p4
>> -I/codes/petsc-2
>> .3.3-p4/bmake/win32 -I/codes/petsc-2.3.3-p4/include
>> ude/mpiuni        -o ex5f.o ex5f.F
>> ex5f.i
>> name
>> SYMMETRIC]
>> name
>> SYMMETRIC]
>> name
>> SYMMETRIC]
>> name
>> SYMMETRIC]
>> name
>> SYMMETRIC]
>> make[3]: [ex5f.o] Error 1 (ignored)
>> Hope you can help. Thanks.
