Implementing an ADI method in parallel
Hong Zhang hzhang at mcs.anl.gov
Fri Aug 24 09:02:35 CDT 2007
David,
We are developing a 2D Fast Poisson Solver
to be included in PETSc, for which, we apply sequential
FFTW in x-direction,
and concurrently solve multiple tridiagonal systems in y-direction,
a kind of ADI-like parallel direct linear solver.
This solver is developed jointly with an petsc user
for an application in the plasma simulation.
Can you give us little more details about your application?
Hong
On Fri, 24 Aug 2007, David Knezevic wrote:
> Hello,
> I was hoping to get some advice on whether the following is possible in
> PETSc: I want to implement an ADI-like method, in which I want to do
> multiple uniprocessor linear solves concurrently (each linear solve is
> quite small, but there are a lot of them).
> This isn't what PETSc is designed for I guess, since one would typically
> do one large solve with multiple processors, but I was wondering if
> there is a good way of implementing this kind of ADI-like method in
> PETSc? Or should I instead implement this kind of thing using a serial
> linear solver, and control the concurrent solves with MPI? I'd prefer to
> stick to PETSc if possible, since it has so much nice functionality
> bundled in it, and has a lot of the MPI stuff already taken care of...
> Thanks very much for the help.
> Regards,
> David Knezevic
