undefined reference to
Satish Balay
balay at mcs.anl.gov
Sun Aug 19 14:55:23 CDT 2007
What do you have for:
nm -ao mvec.o
Also - sugest using the attached makefile.
Satish
On Sun, 19 Aug 2007, Waad Subber wrote:
> Thanks for response
> I removed the lines and I got the following output after executing the make file:
> gfortran -c -fPIC -Wall -Wno-unused-variable -g -I/home/waad/soft/petsc-2.3.3-p4 -I/home/waad/soft/petsc-2.3.3-p4/bmake/linux-gnu-c-debug -I/home/waad/soft/petsc-2.3.3-p4/include -I/home/waad/mpich2-install/include -o pro.o pro.F
> gfortran -fPIC -Wall -Wno-unused-variable -g -o exe pro.o -Wl,-rpath,/home/waad/soft/petsc-2.3.3-p4/lib/linux-gnu-c-debug -L/home/waad/soft/petsc-2.3.3-p4/lib/linux-gnu-c-debug -lpetscts -lpetscsnes -lpetscksp -lpetscdm -lpetscmat -lpetscvec -lpetsc -L/usr/lib64 -lX11 -Wl,-rpath,/home/waad/mpich2-install/lib -L/home/waad/mpich2-install/lib -lmpich -lpthread -llapack -lblas -lm -Wl,-rpath,/usr/lib/gcc/x86_64-redhat-linux/4.1.2 -L/usr/lib/gcc/x86_64-redhat-linux/4.1.2 -Wl,-rpath,/usr/lib/gcc/x86_64-redhat-linux/4.1.2/../../../../lib64 -L/usr/lib/gcc/x86_64-redhat-linux/4.1.2/../../../../lib64 -Wl,-rpath,/lib/../lib64 -L/lib/../lib64 -Wl,-rpath,/usr/lib/../lib64 -L/usr/lib/../lib64 -ldl -lgcc_s -lgfortranbegin -lgfortran -lm -Wl,-rpath,/usr/lib/gcc/x86_64-redhat-linux/4.1.2 -Wl,-rpath,/usr/lib/gcc/x86_64-redhat-linux/4.1.2/../../../../lib64 -Wl,-rpath,/lib/../lib64 -Wl,-rpath,/usr/lib/../lib64 -lm -Wl,-rpath,/usr/lib/gcc/x86_64-redhat-linux/4.1.2
> -L/usr/lib/gcc/x86_64-redhat-linux/4.1.2 -Wl,-rpath,/usr/lib/gcc/x86_64-redhat-linux/4.1.2/../../../../lib64 -L/usr/lib/gcc/x86_64-redhat-linux/4.1.2/../../../../lib64 -Wl,-rpath,/lib/../lib64 -L/lib/../lib64 -Wl,-rpath,/usr/lib/../lib64 -L/usr/lib/../lib64 -ldl -lgcc_s -ldl
> pro.o: In function `MAIN__':
> /home/waad/petsc_test/example1/solvetest/pro.F:38: undefined reference to `mvec_'
> collect2: ld returned 1 exit status
> make: [exe] Error 1 (ignored)
> /bin/rm -f -f pro.o
> Barry Smith <bsmith at mcs.anl.gov> wrote:
> Not sure what the problem is, but
> you should remove the lines
> > mvec.o: mvec.F
> > mpif90 -c mvec.F
> you do not need them.
> Please send ALL the output when you run make exe after the change.
> Barry
> > Hello everyone
> > I am calling a subroutine from my main program, and when I compile the code I get an error message (undefined reference to 'mvec_') referring to the call statement in the main program. I have defined the subroutine as external in the main program using (external mvec), but the problem still unsolved ..!
> > The makefile looks like:
> > OBJS= mvec.o
> > CFLAGS =
> > FFLAGS =
> > CPPFLAGS =
> > FPPFLAGS =
> > include ${PETSC_DIR}/bmake/common/base
> > all: $(OBJS)
> > mvec.o: mvec.F
> > mpif90 -c mvec.F
> > exe: pro.o $(OBJS)
> > -${FLINKER} -o exe pro.o $(OBJS) ${PETSC_LIB}
> > ${RM} -f pro.o
> > include ${PETSC_DIR}/bmake/common/test
> > Can any one help me with this issue please ...!
> > Thanks
> > Waad
> > Park yourself in front of a world of choices in alternative vehicles.
> > Visit the Yahoo! Auto Green Center.
> Be a better Heartthrob. Get better relationship answers from someone who knows.
> Yahoo! Answers - Check it out.
