undefined reference to
Waad Subber
w_subber at yahoo.com
Sun Aug 19 13:30:47 CDT 2007
Thanks for response
I removed the lines and I got the following output after executing the make file:
gfortran -c -fPIC -Wall -Wno-unused-variable -g -I/home/waad/soft/petsc-2.3.3-p4 -I/home/waad/soft/petsc-2.3.3-p4/bmake/linux-gnu-c-debug -I/home/waad/soft/petsc-2.3.3-p4/include -I/home/waad/mpich2-install/include -o pro.o pro.F
gfortran -fPIC -Wall -Wno-unused-variable -g -o exe pro.o -Wl,-rpath,/home/waad/soft/petsc-2.3.3-p4/lib/linux-gnu-c-debug -L/home/waad/soft/petsc-2.3.3-p4/lib/linux-gnu-c-debug -lpetscts -lpetscsnes -lpetscksp -lpetscdm -lpetscmat -lpetscvec -lpetsc -L/usr/lib64 -lX11 -Wl,-rpath,/home/waad/mpich2-install/lib -L/home/waad/mpich2-install/lib -lmpich -lpthread -llapack -lblas -lm -Wl,-rpath,/usr/lib/gcc/x86_64-redhat-linux/4.1.2 -L/usr/lib/gcc/x86_64-redhat-linux/4.1.2 -Wl,-rpath,/usr/lib/gcc/x86_64-redhat-linux/4.1.2/../../../../lib64 -L/usr/lib/gcc/x86_64-redhat-linux/4.1.2/../../../../lib64 -Wl,-rpath,/lib/../lib64 -L/lib/../lib64 -Wl,-rpath,/usr/lib/../lib64 -L/usr/lib/../lib64 -ldl -lgcc_s -lgfortranbegin -lgfortran -lm -Wl,-rpath,/usr/lib/gcc/x86_64-redhat-linux/4.1.2 -Wl,-rpath,/usr/lib/gcc/x86_64-redhat-linux/4.1.2/../../../../lib64 -Wl,-rpath,/lib/../lib64 -Wl,-rpath,/usr/lib/../lib64 -lm -Wl,-rpath,/usr/lib/gcc/x86_64-redhat-linux/4.1.2
-L/usr/lib/gcc/x86_64-redhat-linux/4.1.2 -Wl,-rpath,/usr/lib/gcc/x86_64-redhat-linux/4.1.2/../../../../lib64 -L/usr/lib/gcc/x86_64-redhat-linux/4.1.2/../../../../lib64 -Wl,-rpath,/lib/../lib64 -L/lib/../lib64 -Wl,-rpath,/usr/lib/../lib64 -L/usr/lib/../lib64 -ldl -lgcc_s -ldl
pro.o: In function `MAIN__':
/home/waad/petsc_test/example1/solvetest/pro.F:38: undefined reference to `mvec_'
collect2: ld returned 1 exit status
make: [exe] Error 1 (ignored)
/bin/rm -f -f pro.o
Barry Smith <bsmith at mcs.anl.gov> wrote:
Not sure what the problem is, but
you should remove the lines
> mvec.o: mvec.F
> mpif90 -c mvec.F
you do not need them.
Please send ALL the output when you run make exe after the change.
Barry
On Sun, 19 Aug 2007, Waad Subber wrote:
> Hello everyone
> I am calling a subroutine from my main program, and when I compile the code I get an error message (undefined reference to 'mvec_') referring to the call statement in the main program. I have defined the subroutine as external in the main program using (external mvec), but the problem still unsolved ..!
> The makefile looks like:
> OBJS= mvec.o
> CFLAGS =
> FFLAGS =
> CPPFLAGS =
> FPPFLAGS =
> include ${PETSC_DIR}/bmake/common/base
> all: $(OBJS)
> mvec.o: mvec.F
> mpif90 -c mvec.F
> exe: pro.o $(OBJS)
> -${FLINKER} -o exe pro.o $(OBJS) ${PETSC_LIB}
> ${RM} -f pro.o
> include ${PETSC_DIR}/bmake/common/test
> Can any one help me with this issue please ...!
> Thanks
> Waad
> Park yourself in front of a world of choices in alternative vehicles.
> Visit the Yahoo! Auto Green Center.
Be a better Heartthrob. Get better relationship answers from someone who knows.
Yahoo! Answers - Check it out.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20070819/047f90c2/attachment.htm>
