Sparse Matrix Inversion using PETSc
Dr. Timothy Stitt timothy.stitt at ichec.ie
Thu Aug 16 07:29:38 CDT 2007
Barry,
If it helps I was speaking to some of the project members and they
mention that they actually only need the first M columns of the inverse.
The equations can also be rewritten so that they only require the last M
columns also or first/last M rows. I believe the retarded Green's
Function forms an integral. For the integral in the real plane (which is
repeated for thousands of energy points and hence requires thousands of
inversions) they need only the first few columns as described above.
I would be grateful if you could suggest a possible approach based on
this extra information. I much appreciate your comments already.
Tim.
Barry Smith wrote:
>   Tim,
>    Do you know what the G_r is then used for?
>    Thanks
>      Barry
> On Wed, 15 Aug 2007, Dr. Timothy Stitt wrote:
>> Barry,
>> The group I am working with are calculating what they call retarded Green's
>> Functions of the form:
>> G_r=(E-H)^(-1)
>> where (E-H) is a matrix. Apparently they say there is no way to avoid this
>> calculation.
>> Tim.
>> Barry Smith wrote:
>>>   Tim,
>>>     A dense matrix with 100,000 rows and columns requires 80 gigabytes to
>>> store
>>> the result. 1,000,000 rows and columns requires 8,000 gigabytes.
>>>    With this range of sizes I wouldn't even consider iterative solvers and
>>> would only use direct solvers. I would divide MPI_COMM_WORLD into N
>>> subcommunicators of size n each and have each subcommunicator work on a
>>> collection of columns of the inverse. For matrix sizes of 5,000 to say
>>> 20,000?
>>> I'd make n be 1 and just use PETSc's native LU solver and use MatMatSolve()
>>> and not use KSP at all. For larger matrices you may be able to use an n of 2
>>> to possibly as large as 8?
>>>    Now my numerical analysis training :-) requires me to state the
>>> following.
>>> It is completely insane to compute the EXPLICIT inverse of large sparse
>>> matrices
>>> since they are dense. Please tell me what the inverses are used for and
>>> perhaps
>>> we can come up with an approach the does not require computing them.
>>>    Barry
>>>> Firstly, many thanks to everyone who has replied with information. It has
>>>> been
>>>> very useful indeed. Much appreciated.
>>>> Barry, in this case the sparse matrices would be of ~ order 5000x5000.
>>>> They
>>>> could grow in size but this is the sample matrices I am working with right
>>>> now. We would love a scalable approach so we can deal with more
>>>> interesting
>>>> problems and hence larger sparse matrices. Hope that helps.
>>>> Many thanks again.
>>>> Tim.
>>>> Barry Smith wrote:
>>>>>   Tim,
>>>>>     How large are you matrices?
>>>>>    Barry
>>>>>> Hi all,
>>>>>> I am currently investigating the best way to perform the inversion of
>>>>>> a
>>>>>> large
>>>>>> sparse matrix and came upon the idea of using PETSc as a framework for
>>>>>> testing
>>>>>> various strategies from direct to iterative methods on my sample
>>>>>> matrices.
>>>>>> In
>>>>>> this setup for an NxN sparse matrix A I would have N rhs's
>>>>>> representing
>>>>>> the
>>>>>> Identity matrix and then solve for X. I wanted to experiment with both
>>>>>> parallel and serial strategies ranging from LU Decomposition using
>>>>>> SuperLU,
>>>>>> MUMPS etc. to iterative methods using GMRES etc. Am I right in
>>>>>> thinking
>>>>>> that
>>>>>> all this can be done in PETSc by setting up a core framework and then
>>>>>> varying
>>>>>> the solver methods etc?
>>>>>> I have looked over the sample KSP Solver codes although they only seem
>>>>>> to
>>>>>> suggest single vectors for x and b. Can this be changed to accept
>>>>>> multiple
>>>>>> vectors? Can anyone suggest a sample code that maybe demonstrates the
>>>>>> sort
>>>>>> of
>>>>>> thing I want to achieve...if it is in fact possible.
>>>>>> Thanks in advance for any assistance given,
>>>>>> Regards,
>>>>>> Tim.
Dr. Timothy Stitt <timothy_dot_stitt_at_ichec.ie>
HPC Application Consultant - ICHEC (www.ichec.ie)
Dublin Institute for Advanced Studies
5 Merrion Square - Dublin 2 - Ireland
+353-1-6621333 (tel) / +353-1-6621477 (fax) / +353-874195427 (mobile)
