Sparse Matrix Inversion using PETSc
Barry Smith
bsmith at mcs.anl.gov
Wed Aug 15 16:29:33 CDT 2007
Tim,
Do you know what the G_r is then used for?
Thanks
Barry
On Wed, 15 Aug 2007, Dr. Timothy Stitt wrote:
> Barry,
> The group I am working with are calculating what they call retarded Green's
> Functions of the form:
> G_r=(E-H)^(-1)
> where (E-H) is a matrix. Apparently they say there is no way to avoid this
> calculation.
> Tim.
> Barry Smith wrote:
> > Tim,
> > A dense matrix with 100,000 rows and columns requires 80 gigabytes to
> > store
> > the result. 1,000,000 rows and columns requires 8,000 gigabytes.
> > With this range of sizes I wouldn't even consider iterative solvers and
> > would only use direct solvers. I would divide MPI_COMM_WORLD into N
> > subcommunicators of size n each and have each subcommunicator work on a
> > collection of columns of the inverse. For matrix sizes of 5,000 to say
> > 20,000?
> > I'd make n be 1 and just use PETSc's native LU solver and use MatMatSolve()
> > and not use KSP at all. For larger matrices you may be able to use an n of 2
> > to possibly as large as 8?
> > Now my numerical analysis training :-) requires me to state the
> > following.
> > It is completely insane to compute the EXPLICIT inverse of large sparse
> > matrices
> > since they are dense. Please tell me what the inverses are used for and
> > perhaps
> > we can come up with an approach the does not require computing them.
> > Barry
> > > Firstly, many thanks to everyone who has replied with information. It has
> > > been
> > > very useful indeed. Much appreciated.
> > > Barry, in this case the sparse matrices would be of ~ order 5000x5000.
> > > They
> > > could grow in size but this is the sample matrices I am working with right
> > > now. We would love a scalable approach so we can deal with more
> > > interesting
> > > problems and hence larger sparse matrices. Hope that helps.
> > > Many thanks again.
> > > Tim.
> > > Barry Smith wrote:
> > > > Tim,
> > > > How large are you matrices?
> > > > Barry
> > > > > Hi all,
> > > > > I am currently investigating the best way to perform the inversion of
> > > > > a
> > > > > large
> > > > > sparse matrix and came upon the idea of using PETSc as a framework for
> > > > > testing
> > > > > various strategies from direct to iterative methods on my sample
> > > > > matrices.
> > > > > In
> > > > > this setup for an NxN sparse matrix A I would have N rhs's
> > > > > representing
> > > > > the
> > > > > Identity matrix and then solve for X. I wanted to experiment with both
> > > > > parallel and serial strategies ranging from LU Decomposition using
> > > > > SuperLU,
> > > > > MUMPS etc. to iterative methods using GMRES etc. Am I right in
> > > > > thinking
> > > > > that
> > > > > all this can be done in PETSc by setting up a core framework and then
> > > > > varying
> > > > > the solver methods etc?
> > > > > I have looked over the sample KSP Solver codes although they only seem
> > > > > to
> > > > > suggest single vectors for x and b. Can this be changed to accept
> > > > > multiple
> > > > > vectors? Can anyone suggest a sample code that maybe demonstrates the
> > > > > sort
> > > > > of
> > > > > thing I want to achieve...if it is in fact possible.
> > > > > Thanks in advance for any assistance given,
> > > > > Regards,
> > > > > Tim.
