question on solving the transpose of a system
Randall Mackie
randy at geosystem.us
Mon Sep 25 14:18:49 CDT 2006
Barry Smith wrote:
> Randy,
>> Now, if I want to solve (2) above, do I simply make a call to
>> KSPSolveTranspose(ksp,b,xsol), where I've set b to the right
>> hand side of (2)
> Yes, this is the way we intend it to be used. You should not
> have to construct the transposed matrices.
> Questions:
> Are you using KSPSetNullSpace()?
No
> Are you using right or left preconditioning? Or not setting it?
I'm not setting it, just using the default
> What KSP method are you using?
> What preconditioner are you using?
-em_ksp_truemonitor \
-em_ksp_type bcgs \
-em_pc_type bjacobi \
-em_sub_pc_type ilu \
-em_sub_pc_factor_levels 3 \
-em_sub_pc_factor_fill 6 \
> Barry
> On Mon, 25 Sep 2006, Randall Mackie wrote:
>> I have a situation where I have to solve the following problems:
>> 1) Ax=b
>> 2) (A)^T u = c
>> A is not symmetric.
>> After I set up my A matrix and the preconditioner P (which is NOT the same as
>> A),
>> I solve it like so:
>> call set_P(da,P,l,m,n,period,resist,x,y,z)
>> call set_A(da,A,l,m,n,period,resist,x,y,z)
>> call MatSetBlockSize(A,3,ierr)
>> call MatSetBlockSize(P,3,ierr)
>> call KSPSetOperators(ksp,A,P,DIFFERENT_NONZERO_PATTERN,ierr)
>> call KSPSetInitialGuessNonzero(ksp,PETSC_TRUE,ierr)
>> call KSPSolve(ksp,b,xsol,ierr)
>> call KSPGetIterationNumber(ksp,its,ierr)
>> call KSPGetConvergedReason(ksp,reason,ierr)
>> hand side of (2), or do I have to create the transposes of both
>> A and the preconditioner and just use KSPSolve?
>> When I've tried just using KSPSolveTranspose, the preconditioned residual
>> norm falls, but not as rapidly as when doing (1), and the true residual norm
>> seems not to change much at all.
>> Thanks, Randy
Randall Mackie
GSY-USA, Inc.
PMB# 643
2261 Market St.,
San Francisco, CA 94114-1600
Tel (415) 469-8649
Fax (415) 469-5044
California Registered Geophysicist
License No. GP 1034
