question on solving the transpose of a system
Mon Sep 25 14:16:30 CDT 2006
  Randy,
> Now, if I want to solve (2) above, do I simply make a call to
> KSPSolveTranspose(ksp,b,xsol), where I've set b to the right
> hand side of (2)
   Yes, this is the way we intend it to be used. You should not
have to construct the transposed matrices.
  Questions:
Are you using KSPSetNullSpace()?
Are you using right or left preconditioning? Or not setting it?
What KSP method are you using?
What preconditioner are you using?
   Barry
On Mon, 25 Sep 2006, Randall Mackie wrote:
> I have a situation where I have to solve the following problems:
> 1) Ax=b
> 2) (A)^T u = c
> A is not symmetric.
> After I set up my A matrix and the preconditioner P (which is NOT the same as
> A),
> I solve it like so:
>         call set_P(da,P,l,m,n,period,resist,x,y,z)
>         call set_A(da,A,l,m,n,period,resist,x,y,z)
>         call MatSetBlockSize(A,3,ierr)
>         call MatSetBlockSize(P,3,ierr)
>         call KSPSetOperators(ksp,A,P,DIFFERENT_NONZERO_PATTERN,ierr)
>         call KSPSetInitialGuessNonzero(ksp,PETSC_TRUE,ierr)
>             call KSPSolve(ksp,b,xsol,ierr)
>             call KSPGetIterationNumber(ksp,its,ierr)
>             call KSPGetConvergedReason(ksp,reason,ierr)
> hand side of (2), or do I have to create the transposes of both
> A and the preconditioner and just use KSPSolve?
> When I've tried just using KSPSolveTranspose, the preconditioned residual
> norm falls, but not as rapidly as when doing (1), and the true residual norm
> seems not to change much at all.
> Thanks, Randy
